Yup top cruise Buster, even though I lost a good 80% of my brakes for about 60% of the trip haha (that will be fixed next week whooo). Excelent turnout, probably the biggest cruise i ever been on.
Was it just me or was Husky a goat track? Was interesting to visit but i dont think i could stand that place for more than 1 day hehe.
  • Replies 70
Was good to see SNSW and SAU united!
Good day good cruise good people, all went down smoothly.
My head hurt after all that wastegate when I got home though *looks at BUSTER* hahaha
does neone got more piks den those in tha  gallery???
dam ay? ur 19 an u stil cunnt speel proparlee? auztralean edumacation sistem iz a jok.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
