I want a pair of H3C 55W globes in 4000k- 6000k colour range.
The local shops can only supply H3C in the std colour which look very yellow.
As far as I can find out, Philips, Hella and Narva don't do H3C in colours.
I've considered converting H3 globes but would prefer not to.
I'm not keen on spending HID money but might consider them if the results can be assured
I've searched on here but most results are too old and links and pics don't work.
Edit: I found these on eBay
http://cgi.ebay.com.au/H3C-55W-100W-Super-...id=p3286.c0.m14
Can anyone vouch for these?
there's a couple of sponsors on ns.com selling all this gear, head over there and check them out mate
the 2 sponsors are 'Xenon Xtreme' and 'Androoz'
Xenon Xtreme only has hids?
I was hoping to find ordinary bright white h3c bulb
Couldn't find Androoz but Xenon Xtreme's name is Andrew
Could they be the same guy?
http://www.axsdirect.com.au/WebStore/Stock.php?stock=13
www.axsmotorsports.com at Cnr Fore St & Canterbury Rd Canterbury 7 days
2Yr Wty on these 6000K (pure white) at $250 or less with cash from the store. Or perhaps 8000K (with tinge of blue)
Instal fee of $20 if required
yeah could possibly be the same guy lol
sorry couldnt help you out i thought they sold all that too
mate i special ordered the bulbs from supercheap auto. they are autotecnica super white H3C 55W blue max platinum xenon bulbs. straight fit replacement in my 32 GTS-T with projector low beam. they cost me about $40 for the pair but i get discount there so id say you could get them for $60.
H3C has the 2 spade pins in the back of the bulb and H3 has no spades but uses the body of the bulb as an earth and has a short lead hanging off it. both you can fit H3C bulbs in H3 headlights but you haveto change the spades. i did it with my hi beams as i put blue bulbs in them 2.
any more questions PM me, hope this helps
H3C and H3 are different bulbs.
Yes, in halogen, but they fit the same hole and because the base on an hid bulb is plastic the h3 hid bulb must earth through the high voltage harness so they should be the same bulb in hid.
If I'm wrong please show me pics.
Thanks but the local Supercheap couldn't help.
oh they can help.. just ask for a guy there who knows what he is doing.. tell them to look on ICAT.
if you still have no luck i can get them for ya and post them wherever.
Yeah girls on the weekend didn't have a clue but my searches have found two guys that say the autotecnica bulbs didn't last very long.
I bought some of those Autotechnica H3C's. Shittiest bulbs i've ever seen. They literally fell apart after they got warm!
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
    • It's either an ignition failure or a fuel failure.
