My mate is about to buy a Skyline 1992 gts-t, and we are goin to fly 2500km to pick it up and then drive it home (ROAD TRIP ). Now we both know a bit about cars and shit but dont know a lot about turbo'd cars or skylines. We are wondering what you guys think about the following and if this car is really worth the $19000. The mods include:
5 spoke 18"inch mak sting rims with Pirelli's all round (235's on the rear
and i think 225's on front)
Lowered 3" at front and 2.5" rear
Full GT-R Bodykit
3'1/2inch Jun bl exhuast straight through off turbo with flanges so a cat
can be fittied and taken out anytime
GT-R Front mount intercooler
Exterme multi-puck centre sprung cushion button heavy duty racing clutch
GT-R 400hp rated Fuel pump
HKS superflow pod filter
blow off valve
Turbosmart adjustable boost controller
Nizmo front and back strut braces
Apexi electronic rev/speed meter
Split fire boost gauge
full sony/alpine stereo with 10 stacker (tweeters, crossovers, splits and
6x9's)
Full Cheetah Alarm system and immobiliser.
Now as I said we dont know much about turbo's and was wondering if you guys and girls could tell us some of the things to look out for. As I said we both know some stuff about cars like what to check to see if it has been in accident and stuff like that but next to nothing about the turbo side of things.
Is the $19000 a good price for the car.
It has 85000 Kms on the clock
Also what are the chances of getting this thing to pass a blue slip, as it is SA registered.
Any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/28955-need-help/
The RTA failed a mate of mine for his exhaust (aftrermaket) and Pod filter....
So he needs to find a air box and fit a standard exhaust... to get the blue slip.
I'd talk to the RTA about what you want to do in regards to rego and see what they say. I'd hate to see you /your mate buy the car get it here then not be able to register it.
Loz
https://www.sau.com.au/forums/topic/28955-need-help/#findComment-595621
The seller said he has some stock parts to go with the car as he just cleared a defect on it and is losing his licence so he is selling the car. We will find out what stock parts he actually has as like you said I/we dont wanna see him spend $19000 and then not be able to rego it.
https://www.sau.com.au/forums/topic/28955-need-help/#findComment-595747
i'd get a mechanic to look over it...even if you get the owner to take it to a workshop before you get there (and tell him you'll pay for it). Just for a bit of piece of mind.. (but that's just me)..
have fun on your road trip !! :P
https://www.sau.com.au/forums/topic/28955-need-help/#findComment-596525
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
