just sat my 25/30 in my 32 and the intake manifold i've got wont fit with the clutch line where it is. The line on mine comes out of the bottom of the cylinder, if it come out the side would probably be fine( though couldn't hurt if the cylinder was slightly shorter). The picture on the just jap web site of the hcr32/cefiro one has the line coming out the side, can anyone tell me if it does? and what about the r33 cylinder? is it longer or shorter than the 32 and does the fluid line come out the side or bottom? would it fit the in 32 easily. will be running a 25 slave cylinder if that matters. Any info is much appreciated.
https://www.sau.com.au/forums/topic/289589-clutch-cylinder-for-32/
I've had similar problems, but used a different plenum (CPC).
S14 and R31(aus) have the line out the side.
Pic is of r31 relocated higher.
http://i223.photobucket.com/albums/dd81/30...ster-cleara.jpg
more pics here http://s223.photobucket.com/albums/dd81/30det/
R33 GTSt master cylinder is shorter than 32 and I think the line comes out the bottom (can check if needed).
I got one thinking my plenum wasn't going to clear (as matey had problems with his GREddy plenum) but my custom GTR plenum didn't foul.
thanks guys. I'll mesure up and see if the r33 20mm shorter will work( i've got a 25 box so will keep master, slave the same as factory). Also checked a mates s13 and was same cylinder diameter (5/8) was shorter than mine and the line was coming out the side.
  • 2 months later...
Thanks all ,i just did this works in a R31 aswell RB30DET with redrilled/elongated engine mount brackets holes drivers side by 15mm lower ,passenger bolt holes elongated by half a hole is all it would go.
I took turbo side engine mount bracket (4 bolts off) then plenum Greddy copy just fitted past clutch master cylinder from r33.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
