PM sent
I am really sorry to bother you but I haven't recieved a pm from you. Could you please try again or send me a text msg via mob.
My number is 0429995764
  • Replies 79
sorry mate, no oil lines at the moment.
cheers
hey guys, we are wrecking our r32 gtr with 70,000k's and a damaged drivers quarter, all parts available, see pics for condition (sorry none of it was cleaned before the pics were taken)
r32 gtr Hicas pump and lines (see pic) $150
RB26 pulley (the one the fan bolts too.) $20
R32 gtr standard exhaust turbo manifolds $70
r32 gtr bonnet cable (also have latch, not pictured) $60+$50 for latch if desired
rb26 O2 sensor (1 at the moment, not sure where the other got too.) $60
RB26 r32 gtr engine wiring loom (have 2) $300
r32 gtr dash loom (interior front half loom) $150
R32 gtr engine bay-body loom (the main loom) $350
r32 gtr wiper arms (hard to see, but they are in good condition) $50
r32 GTR windscreen wiper motor (have 2 of, each in good condition) $80 each RB26 injector resistor pack $80
r32 gtr clutch and brake pedal ( have 2 of each) $70 each-(1)
RB26 carbon canisters (times 2) $70 each
r32 GTR accelerator cable and pedal $90 (have 2)
R32 GTR HDPE fuel tank (in good condion some scratches on one side (no leaking or anything serious) $200
R32 GTR ABS unit, complete and garanteed no leaking at ALL... $300
R32 GTR carpet, in new condition... $100
thats all the ones with pics at the moment... other things are:
gtr door cards $120 each
GTR seats $400 each
GTR roof trim $80
GTR dash $150 (no vents, just dash, no welt, no cracks)
BOV return piping $90 (in great condition), have another which has some slight cracking $30
GTR spoiler $150
R32 GTR rear reo, with number plate lights $150
R32 GTR headlights $250 pair
R32 GTR indicators - front $180 pair
drivers side tail light $60
+ loads more... just request for a picture and we will get them up, this is just some of the stuff off the top of our heads, know there is lots lots more... please do not even bother with low ball offers, even with things that we have not mentioned, we will just not sell them... if you want to pay shit all, then we are not the people to get stuff from because all is in good condition...
located on the far north coast NSW (near Lismore), can deliver personally as far up as Brisbane, otherwise postage aus wide for items that we say are alright is fine... at buyers cost of course...
cheers guys
g'day buddy I am possibly interested in your gtr spoiler my name is eric my number is 0421 880 326 please msg me when your available thanks mate :):)
GTR seats $400 each
GTR roof trim $80
GTR spoiler $150
cheers guys
Hey buddy me again just wanted to know if you have a black gtr 32 spoiler :)
GTR seats $400 each
GTR roof trim $80
GTR spoiler $150
cheers guys
Hey can i get a contact number please as i want quite a bit from your thread
or just give me a call?
0433045092
call replied...
drivers headlights sold,
a/c bottle thing (that goes infront of the condensor) sold
hey mate, sorry we dont have one.
cheers
no worries thanks for gettin back to me :)
Interested in an ashtray cigarette lighter plus surround if available. Sorry, can't PM as I am a new user.
hey mate, yeah, will see what we can chase up for you, sure we have the ashtray... will double check and send you a PM.
Hey mate you dont happen to have the complete battery clamp ?
hey champ..do have the coil pack leads from the ignitor...need the plugs all 6 if possible
PM's sent
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
