Wtb: R33 Gtr/gts4/stag(?) Gearbox
Sorry to be a bit off topic Dan, but what car u got needing a 4WD box? If not, I'd be interested to know why u want a 4WD box? :D
Cheers
Paul.
haha, Gunmetal Grey R33 GTS4, 4 Door, my daily,
Dont have a pic atm, ill post one up when i do
Haha, yeah the old one was auto, I've had a bit of a 4wd fetish lately (great with all this wet weather), so i bought this, and its mad, I just got all the gear to turbo convert it, then the gearbox gave up on me. It was perfect, this was fairly random and unexpected (not due to miss treatment, I've babied it :D).
Juddie seemed to get good results from his N/A+T and this is just a daily, so i was thinking stock boost on a high flow, R34 cooler with 7" thermo fan, stock cooler piping and plumb back bov, etc (all the gear i have now collected) should have been quite snappy with the 4.3:1 final drive ratio, and the box being the same as the GTR should have been able to cope :).
Edited by SKiT_R31
Hi man
I have three gtr boxes here in launy
one has a 5 gear syncro gone the rest all good [just pulled out of my gtr
one is perfect in every way [using at the moment
one is a very low kms unknown condition but was bought 3 years ago off david griffiths in hobart never been installed [bought for spare.
stuart 0409135950
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
