  • Replies 70
lol brandon is giving such technical advice now..
rofl hahaahah u make me laugh..
yea sure dan take a gutted cat.. your car will pull so much attention im sure cops would love to bend you over each time and always get you for something
im getting a hi-flow 3" magnaflow ceramic cat installed today at PCE Performance.. quite cheap too
Hmmm pull more attention from something that is imposable to see without taking the exhaust off ?????
Please explain oh knowledgeable one !
I've heard gutted ones before and even decat. They're not as bad as you think. Its really only when you slam the accelerator it becomes really loud.
Dan: make sure its a direct replacement to your car too. Even if its cheap, I wouldnt wanna waste time mucking around trying to get it fit.
i guess u never stood near a car with a gutted car whist its on?
or heard a car with a gutted cat??
try not to be smart ass :P
Edited by Redsuns88
+ 1
Very easy to tell.
All they need is suspicion and they can take your car off the road for an inspection at their insp. station.
Then its up to around a $10,000 fine
Pretty sure he's talking about noise level there. But like mentioned heaps before, unless you've got a custom exhaust system, its very hard to meet the 90dB requirement anyway if you remove restriction to your system.
+ 1
Very easy to tell.
Easy for ppl who know modded cars . . . .
Not easy for traffic cops . . . . (or have myself and 2 mates that run gutted cats just been lucky when pulled over?)
Nothing to do with noise. It's the smell and gas flow that give them away
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
