Driving On Gateway Northside At 3:30-4:15pm Today?
The untimely death of my Rodeo caused a massive roadblock at the boondall wetlands this arvo, if you were caught in it, you have my apologies (but I may also be laughing at you from afar =p).
But seriously, I always knew I'd be one of those people you drive past, grit your teeth and yell obcenities at your steering wheel about, I just didn't know it would be today =P.
Pretty sure I blew a piston, but tomorrow I shall find out from 'Beedham's.
