  • Replies 124
Posted Images
Pm reply replied to :P
Payment sent
payment received :ermm: lol, you sure you sent that pm to me? i don't have one in my inbox?
all other pm's replied to :bunny:
i'd also like to add guys that the software works with all NIStune daughterboards! If you know of someone who wants a single user license so they can tune their car themselves, send them this way!
we're currently struggling with software sales at the moment, so please, get the work out! we need at least 5 people to buy software in order to get this price!
Edited by pyro-ns
Until the first post gets updated, here's a list of who's money has cleared etc:
Interested Parties:
** Please register your interest by replying in here or PM'ing me.
- pyro-ns - Option 1 and 3 - $479.20 - Payment Received.
- msports180 - Option 2 - $258.10 - Awaiting Payment.
- SABBAi - Option 2 and 3 - $423.10 - Awaiting Payment.
- QWK32 - Option 1 and 3 - $479.20 - Payment Received.
- darrinspencer - Option 1 - $314.20 - Payment Received.
- Mr GTS4 - Option 2 and 3 - $423.10 - Payment Received.
- lilcrash - Option 2 - $258.10 - Unconfirmed.
- RBPOWA-(TJ) - Option 1 - $314.20 - Awaiting Payment.
- JRM - Option 1 - $314.20 - Awaiting Payment.
If SABBi is stil wanting to participate, we still need one more single user license in order to get them for $165! So if you know ANYONE who wants a NIStune Single User license, PLEASE send them this way!
Edited by pyro-ns
Payment received! Cheers mate :ermm:
Interested Parties:
- RBPOWA-(TJ) - Option 1 - $314.20 - Payment Received.
Edited by pyro-ns
All PM's replied to!
Interested Parties:
- beRwick_GTRage - Option 1 - $314.20 - Awaiting Payment.
- stenve - Option 2 - $258.10 - Awaiting Payment.
- Hibino - Option 1 - $314.20 - Payment Received.
Edited by pyro-ns
can somebody tell me if this is the standard R34 GTT ECU?
sure is. its for a manual R34 GTT. weather or not yours has been modified already you cant tell unless you open it up and have a look. but i doubt it has been.
i didn't open it & it doesn't have a consult port. Wouldn't that mean it hasn't been modified?
i think it would be pritty safe to say it wouldn't be modified, modified ecu's usually have stickers or plates to say that they are. the consult port isn't on the ecu, i dont know for sure on the R34 but its usually located where the in cabin fuse box is. its a grey plug about 40mm long and 10mm wide.
Payment Received :D
Interested Parties:
- stenve - Option 2 - $258.10 - Payment Received.
Cheers guys ;)
Have replied to most pm's. will get to the others in a bit :D
Interested Parties:
- DSTROY - Opiton 1 - $314.20 - Awaiting Payment.
- lesseragitant - Opiton 1 - $314.20 - Awaiting Payment.
Edited by pyro-ns
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
