hey steve, try some of the boys down at beyond customs. my mate at styled2race may also be able to help you out just mention kinh sent you and get a quote. if not then theres always spoilershop or fibrevision but they are dear. hth also glad to see a new member and hope to see you on next cruise
https://www.sau.com.au/forums/topic/290672-body-kits/#findComment-4867921
Thanx XTC, yeah ,spoilershop is asking for $550 painted and fitted jus 4 a front bumper, while fibrevision is round 450. il give da oda 2 a ring and c wat they av 2 say.
Yeah lookiing forward to a cruise, last weekend of OCT or 1st weekend of NOV is guud 4 me.
https://www.sau.com.au/forums/topic/290672-body-kits/#findComment-4871644
where you get you bodykit from? how much?
Well i have not got the whole kit yet, im doing it bit by bit, cuz i wana mix it up. I got the Trust style front bumper. Getting the kenstyle back bumper soon. Got the front bumper off Ebay , was 250,after postage and shipping, came to bout $375.
You can get the kits also from carmate.com.au, although they bit more expensive. looking at round $450 to $500 for each bumper or skirt plus delivery.
https://www.sau.com.au/forums/topic/290672-body-kits/#findComment-4871655
np mate, give the other 2 a call and see how much. generally the reason why they are a tad expensive is due to the fitting of the aftermarket kits, some wont fit on properly. even if its one of the good ones made around itll only be a 90-95% fit, no kit is perfect fitment unless you go genuine but again they wont be 100% either.
i was going to go custom before and bought a 350z aftermarket bumper to fit onto my v (got quoted quite abit) and kenstyle back and was about to order the wondrous sides but at that time i needed as much cash as i could to open up a business.
definitely will get a kit once i come back from holiday at end of this year and yerh hope to see you on next cruise which would be posted up shortly.
https://www.sau.com.au/forums/topic/290672-body-kits/#findComment-4871919
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
