Since you've done so much damage, why don't you just get another neo from a wrecker and go again. It only died because your oil was on the track. I think a neo with a good sump will last for ages. 90% of rb's die from oil starvation of some description, or a bad tune. Don't see too many die from being pushed too far
i would but i cant find any around for a reasonable price... im not paying 2.5-3K for just a motor like some wreckers want,
mercuary motorsport proved you can push 700 hp from a stock neo and then subject it to drag racing for a while with their VC commo they built for a customer.. i dare say the rods and pistions are strong things!
i shall start a slow build of another block i have on the side... will get it ready for next year
Yeah the things that kill RBs are almost always oil related, fix that and you'll have a very reliable motor, nissan knew how to build them better than a lot of builders out there. I'd trust some guy that built 20 motor a day for years over some muppet that takes your $10k of parts and gets the clearances wrong.
i would have found a way to make it work lol.
well good news anyway i got my new crank tested, fitted with crank collar, ACL race mains and big end bearings supplied, and maching of crank for 400... not a bad price! just need to re-assy. check tolerances and then put it back together
Who is doing the engine work for you champ?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
