hey guys, on the way home just then i was giving it abit of stick, and then it started making noises and was struggling to reach high rpm so every time i tryed to reach rpm and making a struggling sound...current mod fmic and just got boost controller today, i didnt check the engine bay to look for loose pipping because its too dark. but im paranoid now..any ideas?
https://www.sau.com.au/forums/topic/291327-wierd-noises-help/
struggling sound?????? more info, check ur pipes, boost control hoses, remove controller, start from there, new cooler second hand, new cooler or second hand
just had alook at the engine bay seems fine, no pipes out. yer when i give it to it, it struggles to hit high revs. when i got it in hi boost it does it bad, but when i got it on off mode just a minor bit. wouldnt be coz i got stock ecu?
Did you read what I posted? Also, how much boost are you running?
it only happens when i hit high boost, i read a few threads with similar problems and it results in coilpacks, but i dont want to buy them unless im 99% sure :S. by the way if you have faulty coil packs does that mean you get less km's from a tank? because ive been getting less km's recently
question guys, insted of making a new thread i thought id ask here. ive pretty much come to the conclusion my coil packs are on there way out. now im abit short on cash so i was thinking is it worth getting brand new nissan coil packs from justjap or should i save for yellow jackets. would the stock nissan coil packs handle my mods?
take it to a proffesionall
Sighh............ :laugh:
There are a couple wonderful tutorials in the DIY section about fixing coil packs yourself. Lowering the gap is a good idea too (on new plugs). Don't bother spending hundereds of $ until you have exhausted your $free.99 options first. DIY section. Search.
before you go looking at coils, pull your plugs out and see what gap they are and what condition they are in. if they are 1.1mm plugs and have been in there for quite a while they may have worn and the gap may be bigger than 1.1mm so just putting new plugs in will solve the problem and only cost you about $30.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
