  • Replies 169
Posted Images
My damn totally un motorsport interested sister in law decided that she had to have her youngest child's christening today, so I get to spend three + hours in the car driving there and back instead of watching the race.
https://www.sau.com.au/forums/topic/291437-bathurst-2009/#findComment-4873206
