A lot of people blab on about how their gtst are 'stock'
yet they have 3inch exhuast. Really is this stock?
Can you compare a pure stock vs a stock + 3inch exhuast?
the car with the exhuast will win provided both drivers equal skill level.
i have a pure stock nothing done expect a K & N filter. Yet i've bet many other stocks with 3inch exhuast. Shit driver? probably.
Any way my MAIN quesiton is, has anyone here who are PURE STOCK
boosted their car with bleed valve. YES pure stock NO exhuast but boosted say 9-10psi?
ANYONE?
https://www.sau.com.au/forums/topic/29151-what-is-stock-gtst/
Hi mupkant, perhaps the reason you are not getting much response is because what you are suggesting (boost up & no exhaust upgrade) is pretty silly. The standard exhaust on a turbo car is always the weakest link, improving the other links won't help. ie; you are already choking the turbo with the standard exhaust, so turning the boost up is pretty much a waste of time.
Plus, in my opinion, you are risking ceramic turbine failure earlier than if you upgraded the exhaust. This is because strangling the turbine does not allow the heat to escape and heat will kill the ceramic just as fast as excessive boost will.
Maybe that answered your question, in a round about way.
hehe yeh my car was completely stock when I got it. As in factory stock. The exhaust even had the date & month of the car's manufacturer stamped on it. No air pods, boost controllers. Took 11months for the importer to find a good condition factory stock 32. Only thing aftermarket was a Addzest aftermarket headunit.
Anyway i did what Sydneykid was talking about - stock car with more boost. Sure it gave it more power but you could definately feel the exhaust choking everything. Car now has 14psi boost, 3" 5Zigen dump-pipe back exhaust & remapped ecu. Funnily enough its a lot easier to drive because the power comes on sooner due to the exhaust. (I have dyno graphs of what each mod did)
Anyway yes, I have talked to lots of ppl who also tell me "yeh my car was stock too, all it had was 3" exhaust, pod....".
Yeah, mine is exactly what you described, dead stock except for bleed valve. (yeah, I know, that makes me an idiot :D )
It runs about 9-10psi.
For me exhaust note is a concern, the stocker is nice and quiet, its a daily driver and I hate droning exhaust.
Also, to me, I reckon a stock skyline is plenty fast enough for a road car, I'd rather learn how to make the most from a slow car, than to drive a faster car poorly...
Only other "performance" mods are 18" wheels and a tighter diff. Which makes mone pretty much the slowest GTST going around :)
my car only has a a 3" front pipe and dual cat back sys and im not surprised that stock as a rock lines will probably beat me....though no one has yet:D:D i find that with the exhaust u loose the kick when the boost hits at 2.5k but when it hits the 5k mark when full boost is on then its a different story:D
are u planin to run 9-10psi mupkant?? apparently u can get about 9psi by just gettin a full exhaust system??
mupkant,
No problems doing the bleed valve first. The exahust is always a good thing but, if you got no $ then the $90 for a bleeder is cheap and gets rid of the 'two step' boost of the factory controller. You can always keep the boost down to 10psi to save the ceramic turbine.
It works. so go do it.
mate, second thing I did after my bleed valve was the exhaust and I tell u what. Its quiet as anything. No in cabin drone at all and its even fairly quite at high rpms.
U just have to make sure you get a well designed one. Thats why I got a jap brand Jasma approved one. (5Zigen) The damn thing is so quiet i'm thinking of getting rid of one of the mufflers!
Mine is completely stock besides the K&N panel filter, turbo timer, and 2 stage boost controller. I bought it with the controller & timer on it. I have kept up with 32s only having like a cat back system running pretty much equivalent boost & same with 33s, but i have been hosed by a few running decent exhausts & being well tuned. It is running around 11psi. I think the previous owner should have focused on the exhaust first. Early next year i am getting a custom 3" turbo back zorst, along with heaps more goodies....
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
