  • Replies 83
im in melb i can come pick it up also need the glove box front sway bar heater core unit inside the dash all the carpet boot trimming charcoal canister and air box and snorkel and drive window switch no 0403011187 thanks mate really need all these things
Hi, have you still got your tail lights?
Where can i pick them up?
Thanks DAnnie
so i have decided to wreck my r33 instead of fixing it after crashing it. everything for sale is in good condition unless stated otherwise. listed below is everything i can think of but if you need something not listed pm me or call on 0400119068. all interior parts are ready now (12/10) and will have things like motor and gearbox out by the end of the week. i will post pics up on request. feel free to make an offer but im not in a hurry to sell so dont bother low balling!! cheers, Shane
gcg turbo- sold pending payment
engine (inluding front facing plenum)-1300
gearbox-1500
front brake set up (rotors and callipers)-350
back brake set up-150
front subframe-250
steering rack-100
apexi coilovers (adjustable damper)-550
rear subframe + diff (shimmed)-500
front seats-200
rear seat-50
pedals-50
passenger door-120
drivers door (panel damaged, good for window and interior)-70
spare driver door (bought it to fix the car)-100
spoiler and boot-200
seat belts-100 the lot
s2 head lights. (2x left and 1x right)-250 each
fuel tank-50
tailshaft-100
heavy duty clutch and flywheel-100
brake master cylinder/booster-100
front 1/4 panels-120 each
side skirts (right side one slighty damaged)-50
white line swaybar-200
full exhausted system including front+dump pipe, high flow cat-500
big injectors-300
split fire coil pack-300
roll cage (half cage with side intrusion bars made by brown davis)-1000
17inch g-max rims (no tyres)-500
loom-100
tail lights-60
starter motor-40
defi water temp and oil temp gauge + defi control unit (missing oil temp sensor)-400
speedo cluster with 106k on the clock-150
would you have the round thin plate with a wire ribbon that sits behind the steering wheel that plugs into the airbag computer is about 2 or 3 mil thick and about 100 mil across is black with yellow info sticker on it if you have how much with postage to tassie thanks you can contact me on 0408802254 or pm on here your call
Ill take the seat belts if they aren't already gone. Id also like some interior trim (handbrake boot, gearstick boot, carmats...) you name your price
  • 2 months later...
hey mate
i am after a piping that goes from the ic piping to somwhere (i dont know) near the stock bov.....
here is what i am after
if you have it them pm me please
  • 3 weeks later...
Hey mate i know its an old post,
But just wondering if u hav any of these parts i need??
- Frount passenger side quater panel
- The inner Frount gard Lh side were the cooler piping
goes thro and were the head light bolts up
i need that whole section
- S2 LH side, headlight
- Radiator suport bar
- frount reo bar, infrount of cooler
Any help would be much appreciated
if u hav any of the above send us a msg on 0403 236 931
cheers troy..
  • 2 months later...
im after the Heater AirFlow Direction Mode Actuator (underneath the dash passanger side above centre heater box) & a Heater Temperature Mode Actuator (driverside on the heater box pedal lil black box)..
if u got both of the PM me plz with a price from them..
cheers,
Robbie
  • 3 weeks later...
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
