Hey all,
I did a quick search but couldn't find much, i was just wanting to know who you guys think i should speak to about tuning my car in the future? I am looking to purchase an engine management system, and i would like to speak to a couple of tuners around Perth so as to get their advice on it.
Basically the plan is to keep the car NA for awhile, until im off my P's atleast, and then turbocharge. So i would like an ECU that can be tuned to get the most from my RB25DE Neo, but can also be retuned when i do the turbo conversion. I wanted to contact a few tuners and find out which of them would do my turbo conversion, and what engine computer they would recommend i use for it, just so that i don't go out and buy an ECU that nobody wants to tune.
Any recommendations/personal experiences would be very helpful.
Thanks,
Martin
https://www.sau.com.au/forums/topic/291737-what-tuner-should-i-speak-to/
Hi Martin,
You'll get flooded with people suggesting one workshop or another, at the end of the day call some people from this thread, have a chat to them, visit them, and choose someone you feel comfortable with. Opinions are like arseholes, everyones got one :P
http://www.skylinesaustralia.com/forums/Co...hr-t191756.html
Cheers
Paul
Lol ok, cheers Paul. I just thought i would ask because someone may have done a turbo conversion with a specific tuner and had good or bad experiences that could be useful to me. I know what you mean about other peoples opinions though lol, when i asked what ECU i should be using awhile ago, i got 50 replies telling me eManage Blue was great, another 50 telling me it was shocking, and another 300000000000000 telling me to sell my car and buy a GTT.
Cheers for the help though :P
Yeah, I wasn't trying to put you off asking, but ECU choice alone: PowerFC, Haltech, Motec, NisTune, Vipec, Wolf, Emanage, and so on, let alone when you throw tuners into the equation.
Most of the workshops listed in the thread will easily handle a turbo conversion, some I would use, some I wouldn't, but listing them publically always leads to fights. Feel free to PM a few people who's opinions you trust and ask them, that will cut out much of the rubbish :P
Hey Martin,
I've bought a couple of Emanages over and I had no issues and one which was fitted to a R25 R33 made the same power as the PowerFC would. For the value and price they are reasonable however I'm not sure on the power of the unit and modules to tune the vehicle.
If you are going to the extreme of that I'd suggest converting to one of the R34 GT-T models. However, converting the NA to turbo in mild form is pretty simply and can be handled by the normal Nissan engine management.
or u can just *buy* a turbo ECU like i did
it's cheaper and is plug and play - trust me. after putting a turbo kit on - the last thing you wanna have is the headache of tuning an ECU you will prob just wanna get the thing started...
it's a major mind F*ck.
Could you explain in more depth exactly what you have done to your car? Could perhaps help me better... Ive been told by someone who has done this conversion on his R34 that the stock GTT ecu isn't the best option for a turbo conversion as even with a turbo, the ecu will be trying to find signals that a GT+T just won't have
Ive done this conversion for people before, Very easy just use factory GTS T parts( ECU, Injectors etc) and keep boost at Wastegate value and you will be fine.
Well then i think youre the person to talk too :P
Will send you a PM
yeah i've done it to RB20 i think my advice is a mootpoint here
but i definately think just swap over with standard DET parts, use enzed / pirtek for plumbing and heater lines etc... personally if i was to go through that again... i would just sell the car and buy a turbo one...
but... given the circumstances of owning a cefiro, i simply couldn't replace it because they're so rare
Pick a ECU first, then the tuner. Lots specialise.
Location like north or south helps too.
other way round buddy.. pick your tuner befor you purchase an ecu.
most tuners I know wont touch certain ecu's becuase THEY know if it will work for them to acheive the best result's
would be pointless speding 1k+ on a part to be told they dont want to work with it.
like John Hughes, "Choose you dealer before you choose your car! Absolutely."
HEY.
SHUT UP.
:down:
anyway, i will divulge "what i did to my car" cos it's exactly the same thing. purchase the following. turbo, dump, wastegate, manifold, oil lines, intercooler, frontpipe etc. - basically anything that you might need for a turbo bolt on.
little things you should be aware of - as in stuff you should consider BEFORE thinking of a tuner
stainless manifolds are relatively inexpesive. so just upgrade to one of these instead of using the bog ugly standard item. (not important really)
injectors. you need bigger ones. your oens suck. so get better ones. if they're second hand standard DET ones (like i got) get them reconditioned and highflowed by an EFI specialist.
plugs. again. your plugs suck. get better ones.
gearbox. again. your gearbox is gay too. buy a better one.
the reason i suggest to "just go standard ecu"
is because - you're going from an NA engine, and your putting a turbo onto it. your particular engine was not designed to have a forced induction system. but you're putting one on anyway because let's face it, you can't help yourself.
because you're making your car undergo a HUGE CHANGE all at once. by swapping injectors. oil lines. manifolds. cooling systems. ECU's. plugs etc etc etc. you're literally changing your entire system over. you're going to learn a lot in this
but if you go putting SARD 550 inj, FMIC, T07 flange GREDDY E-manage and all this crazy stuff. and you put it all together and turn the key... and it DOESNT WORK (and trus me it won't the first few times) you're going to have a much harder time trying to fix it than you would if you just went "stock parts" then built it up from there.
stock parts are good to learn with - and for the engine itself... as i said, it's a DE motor, meaning it runs at a higher compression rate than a turbo motor. meaning it will have more response and faster boost.
when you first start out you dont wanna put your motor under that much stress
..ps..
trust me
...it's not too late to back out and say "i'm gonna go bowling instead" at this point.
Lol im not doing this conversion tomorrow, its definitely something im spending a lot of time thinking about. Doing a lot of research and asking around, hence why i wanted to speak to a tuner. Thanks for the advice though guys
my advice is.... if you want a turbo car - get a turbo car.. this is a major headache..
the only way i can justify turning an NA skyline turbo
is
if the skyline is
ridiculously well mainained
low kilometres
holds sentimental value / irreplaceable
if one or all of these factors are not met, you would save a lot of money, greycovering hairdye, cut hands, and general years of your life will be added due to less stress
if you..
sell your NA to a Pplater and re-purchase a turbo skyline
R34 skylines aren't uncommon - that's why i did it to my cefiro, is because my car is a rare import and rare to find in the condition it was at the time.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
