  • Replies 50
Well the engine builders don't think it's the sleeves as they don't protrude, and a new head gasket went in 2 days ago. Head was also just faced up when I removed it to fix a minor oil leak. It's very odd... and super frustrating.
This is the third headgasket to go into it now (original, second as a precaution after one of the valves was found to be 3mm longer than the rest and head removed, then this one a few days ago), head has been off twice, and entire engine out twice. A buggered oil pump: fixed... then a longer valve: fixed... minor oil leak from head: fixed... then what we thought was a leaking headgasket: fixed... and now milky oil :(
Just had it tuned at 285rwkw's @ 20psi and didn't even get to use it!
Where is your car these days Matt?
Dane, every time i start thinking engine rebuild for more power stories like yours scare me and i will stick with my 240rwkws odd
Crate engines mate.... Crane engines...
Nice power figure! Sounds like a weapon.. what's it weigh now?? If it's around 1200kg it would be super fast! Do you have a dyno graph to share... I'm interested in SR20 power curves..
I wouldn't know Matt, I haven't driven it!
I'd say it weighs in around the 1100-1150kg mark with everything taken out, but the cage added in. But I'll get it weighed soon enough once it's working. It felt pretty quick on the 250 or so rwkw's I ran ever so briefly at Sandown so 285 sounds promising.
Graph attached mate. It lost some power through the mid range with the cam timing change from it's initial Winton-last-minute tune, but gained a heap up top. Boost response is identical to what it was with 240rwkw's, and on the same boost level it makes a 45rwkw gain. It's also running 11.4 AFR's as we had a boost leak at the injectors so were running on the safe side in case they decided to seal up while I was running, so there should be a bit more in it at the same boost level.
Troy: Stay with the 240 mate. This was not worth the expense and hassles, despite the nice figure. I'm sure it will be great when it's all sorted but I could have been racing this whole time and that I won't get back.
But as Russ said, if I were to do it again I'd buy a crate engine.
285
Pre-Winton last minute tune
2lt tune, same turbo setup
Shall do mate. I'm heading there tomorrow so I'll ask him then.
I'd say yours makes more power across a broader range at the moment. I think once the boost leak is sorted it will improve a lot though but we'll see.
lol ya. came into the left hander, the pfc hand controller cut out. was like WTF! so wasnt concentrating and go into
the marbles i think. then went into the right hander and the back went on me.
skip into 3:00
Which straight is that? The one in front of the canteen?
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
