I forgot that "hoons" were out today. Drove past AIR this afternoon.... The white smoke and crap blowing across Pt Wakefield road was disgusting. Its lucky that roadworks had the speed limit down to 60. Damn dangerous, so you "hoons" cant say that your're not causing problems out there, you are.
just one of the many gold comments taken from daves earlier link, see if you can spot mine :D
http://www.news.com.au/adelaidenow/comment...05-2682,00.html
  • Replies 14.2k
pretty cool huh, he is even fascinated by me oscar (fish), even tho the oscar looks like he wants to eat him haha
WTB RB25 + ecu, loom etc. will also post in wtb section
buy my rb25 and get free car $12500
heres an engine and turbo for you for $1150. It's a 4WD but i can confirm that the 2wd sump will fit, as i have a stag engine sitting in my garage at the moment.
http://cgi.ebay.com.au/Nissan-RB25DET-Turb...=item2ea85e0fc7
Edited by D_Stirls
more air talk.
believe it when i see it. love reading the comments, tyre smoke is toxic, kill hoons, think of the children, etc.
maybe a drag strip again one day but one thing is for sure, ANDRA won't have anything to do with the place while Jane is still breathing......and probably not in my lifetime either.
oh watch out
channel 7 news are doing one of those expose stories this week
guess what major issue they're tackling this time
no its not burnouts
no its not hoons either
its "uncovering HID headlights"
LOL
probably wont even happen in my lifetime.
the debate that mallala and the whyalla 1/8th mile strip is more than enough will probably still be going on. and mike ranns head will probably still be premier.
think i might just stay overseas. adelaide blows.
QFT
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
