  • Replies 14.2k
anyone know if i can get a day pass on my car so i can drive it to a workshop for this saturday ?
car is un-registered and plates are basically expired so i dont have the $300+ for all this
id be going to midas at pt adelaide and back on saturday
you definitely can Mitch
i think its around 30 bucks or so for one of the short term permits
http://www.sa.gov.au/upload/franchise/Tran...tration/MR2.pdf
soooo, my mate has this turbs sittin in his shed, a mate of his bought it from jaustech 8 months ago for
800 bucks,
i took it to simon at morpowa and he thinks its an old trust unit.
has t3/4 flange so will bolt up to the 20, but no water lines.. only oil.
steel wheeled, and thats bout all he could tell me, besides he prob wouldnt put it on the 20.
i can have it for 200,... not sure if i wanna risk it not being what i want, or pick up a vg30...
Couple of pics of the 26 update.
Have removed AAC valve and cleaned it all up.
Removed throttle bodies and cleaned
Removed some coolent things next to oil filter and cleaned.
Will be replacing all intake gaskets and replacing heater hoses with black silicon.
Im glad i got mine for the price i did. $1250 for all 4 245/40/18 :D
Shit head :)
Yeah that was a good deal but DAMN the tires make an assload of difference Chad. I can see how you were going like you did on the track day now
And Luke, be careful working around the throttle bodies. A lot of people clean them thinking they are doing good and end up having shitty idling problems till the end of time
Shit head :)
Anyone who says that semi's are no good on the street really have no idea what there on about. Matt (Whatsisname) has them on his car and he cant believe how good they are either.
800 bucks,
give it to me and i'll put it on my lawn mower :)
Spot on!
hmmm google says its a trust TD-06....
what should i do guys?
Listen to your tuner, that's why they get the big bucks
Has it got any numbers on the CHRA and what are the numbers on the compressor housing?
I was thinking it was a Mitsubishi turbo and if it come up as a TD06 then that would confirm it. What is the compressor inducer measurement?
Ive looked up the thread on here about the special coating thats on them. Have use throttle body cleaner on them. The coating is still on there as i can see.
Cheers for the heads up tho.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
