  • Replies 14.2k
LOL, what have we started here :P ...may just have to set something up....SAU UFC Night to sort out the bluffers from the fair dinkums :D
2 codes will give you a major advantage......if you're a rare breed and have 3 under your belt, you'll be unstoppable.
Oh and Tangles, I can tee up some head gear if you're concerned and even spot you a couple of points.
I'm sure Carl (Bezender) and I could tee up something if there was enough interest......."Last Man Standing" rules, so would have to be played out over a few nights depending on interest.
the bigger they are the harder they fall is what my old man used to say..
sad thing is, the bigger they are, the harder it is to fkn make them fall!
lol absolutely
when in all doubt, kick them in the balls
-D
in UFC you don't necessarily need to be a technical fighter, however, most would struggle with anything more than 3 x 3 minute rounds....including myself these days, LOL.
30 seconds of high intensity is like running 1 km flat out........a hit to the solar plexes at this stage would almost see you out, so fitness (apart from some ability) is key.
It also always pays to know your opponents capabilities, ie. you don't go toe to to with a Thai expert (you try and hold him instead) and you don't go to ground against someone who knows basic holds, you won't get up again and you'll either tap out or go to sleep :cool:
hmmmm this could be very fun!!!
i weigh in at just under 100kg and 6ft tall.....
who's my perfect match? :cool:
if you say sled, get F'd, im out.
im 6'2 and 106kg
time for a ranga battle!
3 x 3 min rounds would have my office job havin ass so tired it'd take me a week to recover :)
im 6'2 and 106kg
3 x 3 min rounds would have my office job havin ass so tired it'd take me a week to recover :cool:
no shit, i'd probably be knackered after round one, unless i stand still and absorb hits like one of those dudes in street fighter with a magical shield, and i do think that is an option, I just need to figure out how to levitate
-D
lol @ ranga battle, you would have to flash your pubes to prove your a ranga :cool:
3x3 min rounds would see me in cardiac arrest.
my job is pretty physical, fill about 9 pallets of stock to shelf everyday,pushing f*k off heavy flat tops and walking
a shit load... .
but surprisingly, my fitness level is disgusting!
ahahahah u are all f**ked then!!!!!!!
Craiggy Boy ill take u on!!!!!!
BTW Dean, i have decided to do the conversion myself, well, the install part anyway.
is it possible to borrow your engine crane for 2 weekends?
will throw a carton'o whatever you drink your way :cool:
i thought Ryan was doing it???
yeah thats cool it's just sitting here atm till im ready too drop the 308 into the race car
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
