They make decent power, but yeah just heard things. Another option is a highflowed stock RB20 turbo, they can hold 225RWKW, and because of the size of the exhaust housing (small), they apparantly got little or no more lag than a 100% stock RB20 turbo.
  • Replies 14.2k
gonna take the td to jaustech which is where it was bought from,
get there opinion before i make my final decision, but tbh, after dale has dug up
that info for me, im leaning toword the 06...
jaustech should be open today?
lol at the poorly written spam im getting
bezender,
susan has sent you this email from http://www.skylinesaustralia.com/forums/index.php.
My name is Miss Susan Godwill, i just went through profile when i was searching for love,life fulture,Well i have no options than letting you Know that I am infected and affected by your profile at(www.skylinesaustralia.com).that is why i wish to have a relationship with you, I will also like to know you the more,And i will be very greatfull to have you as my loved one.so i will like you to reply back to my private email address Above /[email protected]/,And i will also like to send you my pictures for you to know who i am.I believe we can move from here.But bear in mind that Love has no colors barrier,religious,language,or distance barrier,the only important thing love and understanding here is my email address above. ([email protected]).for more explanation.Thank you for your cooperation From Susan.
Please note that Skylines Australia has no control over the
contents of this message.
Regards,
The Skylines Australia team.
that w.hore she told me i was the only one in her life thats it no more checks to her nigerian address to help feed her famaily and get her 10 million in gold bars releast too my bank .
susan has sent you this email from http://www.skylinesaustralia.com/forums/forums.html.
Edited by mid life crisis
jeff had the vg on his 31 rb20, made 220 rwkw with other mods and slid 3rd gear, so must have been half decent.....
i think ill go the TD06, curiosity killed the cat eh.....
if it turns out to be lag city, oh well, i like to learn the hard way lol
a friend of mine has a rb20 with a vg turbo
makes the numbers but it doesnt feel like its making the numbers if you know what i mean.
basically my sil is making 180rwkw's with a kkr 330 with gt28rs internals and he's making 200rwkw's with the vg but my sil can slides easier and pulls away quicker.
you may have to work the engine abit more at higher revs to get a laggy turbo car to slide. i dont really know where im trying to go with this but hopefully you understand :)
someone i used to work with though those emails were legit.
she came in so happy that she was receiving 100 million big ones for nothing.
so happy that she caused a gigantic scene and quit.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
