  • Replies 14.2k
not you too.....I had an appointment with the hairdresser that I just couldn't cancel
shit pete, your hairdresser must have a pretty awesome car with the amount of times youre there.
As i said in the PM i just sent you i can't be sure about the 3700rpm response as i am only going on the bigger trim versions of the TD06.
Here's the pictures, as you can see it's identical;
FYI the one pictures is for sale for US$300
as long as it starts spooling hard by 3g ill be happy, my 33 with hiflo vg30 spooled at 3200 with full boost at 3800-4000
and that could slide with ease....erm when i took it to lala.
im just gonna take the risk and go for it.
Just letting u guys know there is a huge rbt on south rd near the over pass getting traffic both ways and heaps of cops near cross rd.
i went along south road today
was not fun. 25 kph for over half an hour, and total f**king gridlock on a sat afternoon only ever seen during rush hours on the weekdays. should have gone up portrush road
-D
too many roadworks at one time...
everyday of the week, i come across major works, from the new expressway up north
to the ghey tram overpass on sth rd.
not to mention pt rd in peak hr, that shit can cause hemorrhoids
its friggin stupid
we used to have tramlines extending up oconnell st and into prospect and then they removed them
now theyre building new tracks, using trams that are crappier than those offered back in the day
so, in 40 years are they going to pull these tracks up again? and then rebuild then in 100 years?
Lots of real short term planning going on in this city
Heres a brainstorm - different modes of transport having their own real estate?
it works enough with the Obahn - why cant we have obahns going out every 45' from the CBD ?
Why cant we get bike routes alongside said routes, just like linear park has?
Get the cyclists off the road and onto their own dedicated paths alongside the tram and obahn tracks, emphasize train and tram and bike before busses (because public transport that has to wait for auto traffic is an instant fail), get the trucks off the arterial roads and onto their own bypasses and get rid of this 50kph default speed limit BS.
Thats my rant for the night
-D
ugh. what a morning. bottomed out hard. smashed my intercooler mounts. bent my castor brackets. probably f**ked my exhaust. rails look alright.
probably take it down to a chassis joint on tuesday to make sure everything else is fine, then start replacing the bent bits.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
