  • Replies 14.2k
Pods = HAI = Fail
Air Box = CAI = Win
Put one of these over the pods and save a shit load of money.
Anyone know if 33gtr seat sits lower than 33gtst? Starting to get a bit annoyed with my head rubbing the roof.
It should be lower, they are lower than 32 GTST seats.
hmmm, ill give it a shot. if the kit gets here by friday, ill have 2 weekends to do it before
the rb20 goes in...
actually looking forowrd to gettin my hands dirty and doin some shit myself on this build, makes it more pleasing.
starting on ripping the 30 out today, perfect weather for it! :P
yeah was an awesome day, i dropped one out too
would anyone have an idea why my 20 would have a crossover pipe without a bov adapter?
Cefiro motor
no factory BOV
mine was the same :)
Still got that misfire mate?
Yup. Friday afternoon, a mate picks my car up from the tuners after having the belts tightened and the tuned slightly modified. Ask's me if he can take it for a spin round the block, i say yes. I get to his place after work to pick up the car...he tells me it is sounding weird, i start the car...it sounds like a WRX :P , i think either coilpack or sparkplug...ring a mate, and he sort of confirms it, and give me some soultions to fix it, they dont work.
Luckily my mate has a garage out the back, so i drive the car in, and pull out the coils and plugs. Coils look okay, plugs....are black and 1 of the 6 was moist. I swap the plugs around, aswell as the coils, put it back together...still the same - now i think about it, of course it would. So i leave it for the night.
Come back on Saturday with the stock coils and plugs that were in the car before. Change plugs first, start car...runs fine, rev it a bit, still runs fine. So i take the car home, all fine, take it for a spin once i get home, it stalls randomly 1-2 times, but other then that runs fine.
Take it to work today, runs fine, on way back from work, the car starts loosing power, dropping revs, and jerking, aswell as stalling at the lights 2-3 times. So i take it back to my mates place, where it is now until Tuesday, when i can take it back to the tuner.
My guess is either wrong plugs - put in Iriway7 first, then swapped back to PFR5G11
or
A Bad tune - Too Rich, not good with this heat.
or
Ignitors may be playing up in the heat.
It had been running fine until Friday afternoon, had gone about 1000km before then.
Cefiro motor
no factory BOV
mine was the same :P
ahh ok, cheers for that, hope your right haha, rb20de+t would suck.
wonder why it would have ecr32 written on the ecu then?? hmmmm
also, changed my mind on the turbo AGAIN.
did a dummy fit, i would need to run a spacer on the flange coz the compressor housing hits the manifold
before the studs are tightened, and i need an elbow made up.
i do however need a coolant line, the one that goes from the back of the block to the back of the turbs...
anyone got one lyin round?
need a full pic of the car with it on to make up my mind, but i bet it serves its purpose down the back straight of lala.
It looks bigger in those pics than it really is, its about the same size as Andrew's.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
