  • Replies 14.2k
ahh ok, cheers for that, hope your right haha, rb20de+t would suck.
wonder why it would have ecr32 written on the ecu then?? hmmmm
also, changed my mind on the turbo AGAIN.
did a dummy fit, i would need to run a spacer on the flange coz the compressor housing hits the manifold
before the studs are tightened, and i need an elbow made up.
i do however need a coolant line, the one that goes from the back of the block to the back of the turbs...
anyone got one lyin round?
looms are similar, ecu's are similar
mine's a ceffy x-over pipe on a 32 engine. its a chop and change part, usually means u need the rubber elbow from the AFM with the extra bits if you want to run the factory bov
So are you saying Cefiro RB20's have no BPV/BOV at all? So they come with hektik flutter from the factory?
from what ive found
unless they've popped their donks in j-land and ended up with a 32 engine haha
from what ive found
far out, I guess that blows the "its put there for a reason" theory
Cefiro crossover pipe here:
http://cgi.ebay.com.au/cefiro-rb20det-cros...=item3ef9e4bb5b
yeah look exactly like that.....
if it WAS factory na, it would still have to run na ecu right?
wheres dale when ya need him :P
mr hks, judging by the cars that usually have those stickers i thought that stood for Hyundai Kool Skids
u got the wrong car :P o yeah i said that
ive seen that wing b4
lol all good dude, gives it the track look. n i know how u track racers look down on us mountain passers :)
Edited by Inline 6
u got the wrong car :) o yeah i said that
What you on about?? I dont have any HKS stickers :P
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
