  • Replies 14.2k
Hey Craig, Trent replied in that 17C thread you started in the Forced induction section, Seems it's a bit laggier than first thought with full boost (21psi) @ 4800RPM. That makes it as laggy as a TD06SL2-20G which would put you over the 300kw mark. I guess the old tech' compressor wheel isn't as efficient as the new stuff.
On a slightly un-related note, I PM'd that guy you said and he gave me all the ins and outs between the HKS 2530 and the Garrett 2860RS, plus he even gave me the part number for the HKS specification Garrett cartridge. Top bloke, so thanks for sending me to him :P
Would seriously love to know how the f**k you come up with that 'aids ridden' comment
-D
So you bag his taste in women yet he can't bag yours? :P
Come now boys, different strokes for different folks :P
mate
i never said that any tattooed chicks had aids
i just said they dont do it for me
big. f**king. difference.
or do you care to argue on the contrary? You think he would have said that about a white chick in a bikini with tatts? I dont friggin think so
-D
Edit - Dale and Dion, I think you're spot on the money there.
mate
-D
rofl, this is why this country is f**ked, say whatever you like about a white person, it's fine, as soon as you say it about a black person, it becomes a matter of race. Reminds me of a Russell Peters skit along the same lines
No skin off my nose there Ben, just a bit of social commentary. Let the flamage continue
"was he black ? "
"i ono , if you say he was black then he coulda been black"
RUSSEL!
YOUR SHOW
MIND BLASSSSSSSSSSTING
i didnt say jack about race mate
i didnt bring that into the equation - insinuating a chick has aids? I could understand it if it were gemma ward or miranda kerr, cause I can see their ribs as a matter of fact, but i dont hear anyone saying they got aids or anything
no skin off my nose here either, but i read about these reports claiming australia is a racist country. i'd like to believe otherwise, but the majority of the people in this country leave me disappointed
-D
-D
Did I say you mentioned race? No. Others did and I was merely participating in some social commentary...
I also don't understand how seeing ribs means you have aids. You can see my ribs if my shirt is off, does this mean I should book myself in to get tested? :P
Ah f**k it... have fun boys. Night
EDIT: Mitch, good to see someone here knows what I'm talking about :P
lol ben. chillax. i dont actually think she has aids (though there is a chance), but i do think shes an ugly scragg.
Aids ridden because she of negro american appearance... bit racist my friend Dave :cool:.
youre saying negro american and youre calling me racist? its african american.
youre a lousy person wayne. you should be ashamed of yourself.
and its only racist if i discriminate. which i dont.
(and interestingly, the fact that shes black didnt even register, i just saw an ugly scragg)
and luke, you probably should book yourself in after our experience the other week. :P
sorry i held it from you. :P
Edited by scandyflick
Well when it comes to commentary, satire and polemecy, you gotta be a bit more obvious
Well it never hurts, and if you got ribs showing then I can always cook u something or even buy u a burger yo
-D
-D
No thanks, perfectly healthy.
Damn late night phone calls... again, night
Oh and I'll work on all that for you Ben, promise
And Dave, f**k you, now I know why I'm itchy
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
