i can live with that carl.
Oh, and Dave, you will be pleased to know that ill be seeing that chick i showed you on my phone friday night.. :banana:
bout time. i thought you were actually a homo for a while there.
  • Replies 14.2k
shes a mega skank. clearly gagging for it. and he preferred to sit around with a bunch of dudes drinking beer watching midget wrestling.
go figure.
Edited by scandyflick
replace skank, with freaking hot.
and i didnt feel like driving out to Parafield Gardens, and it was yeah...that special time.
However i will redeem myself hopefully this weekend.
and jack, i would put up a pic, but yeah..mods will go nuts.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
