  • Replies 14.2k
or just run some tubing from the engine bay and place the other end right infront of your balls. youll soon know when to back off the accelerator
haha ouchies... painful to imagine :) < never seen that icon lol
Rich people that can afford to mod an already really exensive car shit me >_> lol
hey man you gonna do another cruise again? i liked the other one july.. i think it was b4 that person damaged your car
some one post inbetween me already! any1 know if when you get a custom number plate is that the only 1 of its kind in all of aus or can you say for example have a "RIPP3R" with dif state letters?
EDIT 4 CRAIG :Craig: they are posts 7 mins apart im going in and out of every post and shit... i havnt spent much time on these forums and i keep stumbling over different things... besides im allowed to dribble in this thread and i saved 1 post and did it in here for you.. happy?
il be on my wat to vilis soon anyways so there will be peace and quiet just for you :)
This may answer your question.
Man....Lax.
you need to go have a wank, get some tension out.
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>&">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
lulz
ha ha no worries dude, my run of bad luck didnt end there!!
went to ''smooth'' garage today to pick up the new 20.
well, Cam cover, timing adjuster thingy, coilpacks, crossover pipe, AFM all missing!
rang jeff, not happy. im not gonna buy it till all the rest of the parts are there. simple.
rang jap motorsport, they have one, engine and loom, COMPLETE for 1g.
had compression test before removed, 145 across all 6.
Hey craig
Ring TT and ask them of they still have this engine sitting down there. AFAIK it has just been sitting in the corner since it was taken out. so it would have done <1000km's since having a standard rebuild.
http://www.skylinesaustralia.com/forums/Tu...turbo+tune+RB20
Edited by D_Stirls
Hey craig
pretty sure its in an S14 now
That's what they put it in for the experiment but that's running a RB25/30 now (Their Orange Drift Car). Last time i was down there getting Jeff to tune my car it was just sitting on a stand in the corner. Michael said that if someone wanted it they could have it (For the right price)
Edited by D_Stirls
there 20 will prob be more than im willing to spend tho? did he say how much?
that 25 is missing too much shit, key word here is budget.
You'll ahve to ring micheal and ask but i don't think that they'd be after that much for it, it was built from parts that they had on hand.
Just had a look at that 25 listing and it isn;t missing that much. could get the rest of the parts for around $400.
Oh and they might think that it's an R33 engine but look at the CAS it's actually a NEO, so you could have a win there.
Damn that sucks balls man, what a fk around.
We nearly had my engine out by about 3ish this arvo. My mate went back to do a bit more when I went to work around 4 so hopefully the old 20 is out and we're ready to prepare the new one to go in tomoz.
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
