  • Replies 14.2k
Here's a old-school Toyota Celica Turbo... owned by TOM's then by Trust:
It apparently magically dissapeared after a few races in 1983. Now look where it's ended... in someones backyard laying to rot:
It's crazy how much abandoned cars there is in Japan... all just rusting away.
I'm looking at doing a 100k service on the GTR in the coming weeks. Should I replace my water pump with a standard pump or n1 water pump
Go see Rob And Rocco at Synergy, they get Tru-flo pumps fro japan, basically an N1 copy for a fraction of the price. Put one on my old 33 just before i sold it.
just took the 200 for the first spin in a few weeks. tis nice. crushed exhaust is making itself painfully obvious however. has trouble boosting past 0.8 bar, used to get out to 1.2 easy. gotta replace that soon, and install my ebc i reckon.
Jap Motorsport = Adelaide Jap?
I was going to buy a RB20 long motor for $1k, until I found a complete RB25DET cheaper :huh:
no. Jap Motorsport - JMS www.japanesemotorsport.com.au
Adelaide Jap = Adelaide Japanese Imports www.adelaidejap.com.au
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
