  • Replies 14.2k
LOL. I'd love to see the rain dance for that.
it involves big macs, jelly donuts and the neighbours soundtrack.
it aint pretty.
Nah, gotta be something better than that...
its the best i could come up with on the spot. ill work on it.
In other news, put an offer on a house, missed out by a measly $1000
its a sign that you should build the 'R instead.
i have a nitro circus ticket, a jason alexander spectacular ticket (george from sienfeld standup), f1 ticket in melb and finally my bali plan ticket
but, im really wanting one of them luke, lol
who the fk are the nitro circus tickets through !
all i keep hearing is they are coming but i cant find any info at all
Fking yeeeeeeeewwwww the Silvos is coming along nicely now :P
New loom is bought, thankfully I guessed the right one to match my hacked one out of the 2 different Ceffy looms JIS had :P Engine mount sussed, turbo and ancillaries have all been transferred to the new motor, clutch and flywheel are on.
Tomorrow will hopefully see the rad getting a proper flush, the gearbox bolted up and the new loom connected up.
If we get lucky the motor may even be sitting in the bay by days end but that might be pushing it :)
I can hear the rev limiter bracing itself for some punishment already :D
Edited by AndrewJZX100
Fking yeeeeeeeewwwww the Silvos is coming along nicely now :D
New loom is bought, thankfully I guessed the right one to match my hacked one out of the 2 different Ceffy looms JIS had :D Engine mount sussed, turbo and ancillaries have all been transferred to the new motor, clutch and flywheel are on.
I can hear the rev limiter bracing itself for some punishment already :)
LOL!
between you and me, that motor had no chance of a happy life haha.
i give it 12 months and we will prob both be looking for RB20's again lol
my missus was gonna send me there for xmas pressie, but would
have worked out really dear for x2 flights etc etc...
so i settled for nitro circus, win
might see you there!
donno where you get them. my missus mom got them for me for a xmas present.
Edited by Import S13
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
