  • Replies 14.2k
urge to make fast n furious qoutes about nos circus MUST RESIST
i thought travy pastranas retired from moto x after he landed the double backflip
edit apparently he still a nut case :D
Edited by Inline 6
I love it when my silvia gets a coolant leak, and its coming from a hose at the rear of the motor where I can't even get my head to see where its actually coming from to fix it - CHEERS! ffs. CBF.
Looks like I'm driving the ute to work -_____-
haha its an SR man, you could put fuel in the engine and oil in the petrol tank and it would still smash the limiter happily.
CA* lol.
And yeah just waiting to flog the ute off Dan, its come in handy so many times.
Wouldnt mind keeping it a bit longer but no room and the money is better in my pocket I spose
CA* lol.
how much u want 4 it? tow bar??
interested
Sounds like the hoses that lead to the heater core
-D
The ute or the S13 Dan? :)
Yeah it could very well be Ben,
So hard to get even my hand in there to see/feel whats going on. I can't pin point where its coming from.
Hopefully a good friend of mine will help me out.
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
