  • Replies 14.2k
Or I can get super discount at Lakeside if you ask me nicely
dear Luke,
Im writing to you NICELY, in hope you may be able to help me with
your trade discount at Lakeside Nissan.
I am in need of:
12x Exhaust manifold stud
1x exhaust/turbo Gasket Kit
4x turbo stud
1x bomb (preferably afghan made) to blow this bitch up.
thank you.
sincerely
Craig Smith.
the new 20 come with a flywheel, which is in better nic than the one i have...
only thing is it has some very light surface rusty lookin stuff on it,
will i need to clean it off? with what??
if i was to sell a car interstate without the guy coming to look at it, how do i transfer rego to him as he wont be able to sign the paperwork?
i'm guessing i need to do it on the rego site or something? i'd just like to have a desposal notice to hand in as soon as it's gone.
Research tells me that i should just leave it and run it, the clutch will rub it off....
i have so much f*king work to do.
just sign your part of the disposal notice and leave it in the glovebox. he will have to transfer the rego from his end.
yeah good idea Damo.
Not only will the buyer get it, but the truck driver, the people that load/unload it, and whoever gets there
greasy little hands on the car....
idea of the century, three gold stars for you.
haha its an SR man, you could put fuel in the engine and oil in the petrol tank and it would still smash the limiter happily.
not quite. sr's have a bit of a love/hate thing with rev limiters.
its the rb20's that you can do that do and still live on limiter without harming it.
lol, i want the disposal notice.
so incase he never changes the rego to his name in the other state it cant be linked back to me for any stupid shit that he might get cought for.
there would have to be away to do it online but im wanting the notice with his signiture onit.
hoping someone on here might have done it.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
