  • Replies 14.2k
Okies, so um, do you guys get alot of attention in they city with your skylines ? i mean like , in my little shiity town, i get alot of positive attention, but always the jealous crew that will give ya the finger, just wondering if any else gets that experience just because you own a nice car??
well i have just been tested for glandular fever so if the results come back on the bad side there will be no work for me for at least the next 4 weeks. No money over the summer :D
fingers crossed for ya mate! if it is glange feeling sorry for ya cos ur gonna feel like poo for some time till your body gets back on its feet! if ya need anything sing out
not that much hate but sometimes a lil disrespect :D ive had about 3 chicks say "nice car" while stopped at the lights thus far since i bought it
my bro had a turbo swift that could beat v8s now that was a car that got the finger at least once a week
Yep. My mate fashioned up an aligning tool with an old input shaft out of one of his boxes, works fking mint :)
The sil is so close to being done. Turns over mint but theres no fuel pump priming before hand. I've been told theres an extra wire you have to run when going RB in a sil to get the pmp going, which the new loom wouldn't have, so looks like all I'll have to do is identify that wire on my old loom, do the same to the new one and bobs your fathers brother.
ok, so do nee some sort of special tool to line the clutch up when i put it on?
To line up the clutch plate to centre with the pressure plate on? Sure do. If anyone has one, I'd like to borrow it next weekend for my manual conversion :)
:P
Roo, I got a clutch aligning tool :O
You the man Luke! :)
Moved the GTR box from the back of the Stagea to my garage on my own ... jesus! Not doing that again!!! :P
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
