  • Replies 14.2k
^^^LOL Craig.......you can be a funny bugger sometimes :D
Kietz, we're all in suspense..........why the change of heart all of a sudden?
Didn't the 34 bits bolt on the way you may have anticipated?
well i took my car through i.d check they were all cool with it all needed was change was the bonnet and tint removed, i did all that chucked a standard r34 gtr bonnet on and removed the tint went back and then they said i need to change the whole front end back to the original... such a big headache! so now i gta change the whole front back to r32.. got all the parts now, just have to fit.. once its done the r34 gtr will be back on with a fresh respray and r34 neo engine =] definately be seeing me on the cruises to come!
he came from the shallow end of the gene pool,,,, what a moron
DING DING !!!We have the winner for the biggest idiot in world
and Damo are you that bored your surfing every forum ????
nah i dunno about that one, my mate (mechanic, known by a few as a real good skyline mechanic) worked for a dealership once, he said a lady cleaned out her engine with detergent and a hose because when she dropped the oil it was dirty :D
ilold
a few happy snaps from last night, new lens for my camera,, these were handheld not tripod and from backyard , maybe try it with tripod next and black specks would be lens dust from trees wind or aliens...lol cant be stuffed fixing them , clean the lens instead...lol
1300mm lens and 2600mm lens shots and highly compressed photos to post on the web... hi res looks sweet
just for your Entertainment today,,,,lol
ilold
thats the outside of the motor though
n call me obsessed but the faint white lines starting from the top right on the moon there remind me of a basketball :D
Edited by Inline 6
looked more like a moldy grapefruit...lol
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
