hrm that looks good with white. methinks they'd look nice on my r32 >:)
-D
Well I'll have a set coming next week. So you can see what they look like. But I don't think you want the sizes I'm getting.. Bit too 'illegal' for your liking.
  • Replies 14.2k
yeah i think i'd be after 18x9 at most (34 gtr rim size) or the 8.5's.... but will be nice to see regardless
-D
much hope the 31 sounds like this when finished with side pipe
no craig, you want yours to sound like this
or this on idle
btw, my side pipe will be similar design and hopefully pop flames like such too
ok i just cant not post this, i know ill make a few of you blow your load.
http://speedhunters.com/archive/2009/12/08...31-skyline.aspx
fanki's car
lowest 31 in australia. loves munching front guards too
Edited by Matty 31
/chop images of pron 31
sounds O-K.....
thats how decs is gonna make my cooler piping, looks like shite, but atleast its much shorter...
Kye, can you link my aquarium to NS.com for me dude?
cheers
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...=STRK:MESELX:IT
just did it craig
http://www.nissansilvia.com/forums/index.p...howtopic=419835
Does anyone know if regency will accept R32 GTR front brakes instead of R33 GTST front brakes when registering a 25'd 32?
Here is the part about that in my letter: 10. That Nissan R33 296mm X 30mm disc brakes and calipers are fitted to the front axle.
If I have to use them its fine, but my understanding is that brake wise R32 GTR > R33 GTST. Maybe I should give them a call and ask..
I think r32 gtr non-brembo brakes are the same as as r33 gtst brakes anyways
ugh. went to the dr's about my sleeping and anxiety issues, instead of finding a solution, "heres some drugs, enjoy." f**kin.
anyone got suggestions on what torque to do a hubcentric bolt on spacer up to ?
110nm + some loctite.
asking for a little help
posted in borrow section too..
me 'na mate are rebuilding a suzuki f5a 543cc 3cyl hatch atm, engine is out on ground
cant get the flywheel off, etc.
need to borrow a flywheel stopper holder lock tool
anyone?
anyone?
rattle gun works a treat ;D
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
