  • Replies 14.2k
just watchin that vid that matty posted again, and noticed the AFM on the strut tower, not even
connected to the intake... how does that work? me want?
it doesnt. had something to do with the regulations specifying that it had to be connected. didnt say it had to be connected and in use though.
Anyone know of a black R34gtr getting around ?
i used to spot one regularly in town during the day craig, led tail lights and big(ger than stock) rims, and if i remember correctly it had personalised plates
havent seen it for a while though, say around 3 months
ahhh ok, i thought it was so you could run a solid pipe to pod without havin AFM in between....
but upon actually thinking about it, it wouldnt work..
Well i had some what of a sucessful day. got the Cressy i bough a few month ago running (just an ignition issue in the end) but then found that the headgasket is stuffed (which i suspected anyway). So if anyone wants an 1993 MX83 Cressy with 178,000km's on the clock with a blown headgasket you can have it for $1300. Or i'll do the gasket myself and put $3000 on it.
Also started pulling parts off the CA to clean them up;
EDIT!!
As for the R32 GTR Vs' R33 GTS-t Brakes they both have the same diameter but the GTR rotors are thicker (32mm V's the GTS-t's 30mm)
Edited by D_Stirls
argh, ive fiddled too much and now the GTR doesnt run smoothly...
ive posted a thread in forced induction, but still:
ive:
removed all the recirculation piping, and blocked off the inlet pipe holes
moved the boost solenoid to a better place
cleaned the AFMs
and put the stock breather hoses and PCV back on, no longer venting gases to atmosphere.
drove fine (with better power steering mind you!) for about 1km, with small amounts of boost,
but now it barely runs, and is stuttering all the time... any ideas what ive done?
where do i start :blink:
Hmm, have you asked if that was okay to use on the AFM's?
I know when I cleaned out AFMs working at sinergy we used Brakecleaner which is a thin liquid that smells really really strongly you can almost taste it and it drys with no moisture left behind.
It has to be the way you plumbed up all the piping etc
i use the stuff at work all day long to clean electronic components
and if it was the pipingm, why would the car run fine for the first half of the trip?
Could have done something and made it over fuel, and now your spark plugs are fvcked hence why it took some time.
Maybe take out your spark plugs and have a look man otherwise I got nfi lol.
Bed time, will check this tomorrow though good luck :).
Bed time, will check this tomorrow though good luck :) .
does anyone know if altering the length of the inlet piping after the AFM will alter the way the car runs? or should the tune pick this up and self-correct??
I know someone who has a R34 Vspec 2 in black ???,, she lives in north adelaide area, dark hair , has a built forged motor in it.
actually she looks a lot like that chick damo...lol, only a model not athlete..lol
asking for a little help
posted in borrow section too..
me 'na mate are rebuilding a suzuki f5a 543cc 3cyl hatch atm, engine is out on ground
cant get the flywheel off, etc.
need to borrow a flywheel stopper holder lock tool
anyone?
a screw driver run thru one of the balance holes is usually enough, if not try a steel scrap through the starter hole ..
if you can get one bolt off, use a steel flat bar and make one,, drill a hole in the end , pop the bolt back into it and use a bellhousing bolt for the other end.. works a treat. WD40 helps too..lol
some take a light heat from a heat gun or plumbers torch to get loose.. but dont overheat the rear main seal or it will melt.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
