I want for the S13 man
Craig's picking up a couple of the rims tomorrow to trial fit them so we'll see if he's going to take them.
I only cleaned them up today and they are in a lot better condition than i though.
I also have these which are 17x7 Volk GT-P copies. you can have them for $550;
Edited by D_Stirls
  • Replies 14.2k
popped down to adelaide tyrepower today, theyre letting me use the workshop, their tools, and their collective experience with regency to get me off defect, cool, the weekend i spent helping them relocate just paid for itself. :D
Lets put it blunt, he'd be the first person to 'lol' at anyone who did get defected if he DIDNT get done :(
only if its deserved. i wouldnt just laugh at someone being defected for the f**k of it, unless i know that person that is.
had a good laugh about it with bengi last night cause we both got done for some ridiculous shit.
Edited by scandyflick
I went to the start up and made my donation and you could tell straight away what it was going to be like so I didnt go on the actual cruise.
To be honest ive lost a bit of respect for mark to know whats going on with these cruises and nothing be done only to be making it harder for the rest of us later on. I never thought I would say this, but I agree with James, sled and the others that wont be doing a cruise again.
This is not Mark and Jules's fault at all...........they too would be affected by all this as they were the organisers....and i bet you all the tossheads from yesterday didnt even think about how this would affect the organisers.....
Theres a time and a place for skids. Public roads are not it.
-D
+1
Your biker mates Roo,. were some of them in 'team swat' ? I know what it stands for. I'm just asking as i know some of your biker friends.
Don't know how well you know the guys at "team twat", but they're a bunch of squids. Its these guys we've told to f**k off. No skill, no brains, no respect.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
