Aussie's will most likely loose this test match and damn right they should....a poor first innings performance by them see Pakistan in a easy position to take a win...currently 3/65 and only needing 176, which i think that they will comfortable get....
will make an exciting third test :D
:) we win!
  • Replies 14.2k
Indeed! Great bowling and Ricky's a great Captain no matter what the knockers say :)
Your right. i cant believe people say ponting's a shit captain. The same people say Johnson is a crap bowler.
ffs. Ponting was announced the highest winning captain in cricket history.
Johnson has the most wickets around the world with the best bowling avg. :D
johnson IS a crap bowler- being a lefty tho he ends up getting the angle across for plenty of edges from RH batsmen
strays far too short and wide far too often.
needs to watch bruce reid at his finest to see how a proper left arm opening bowler does the job.
ponting is a decent captain no doubt, however if warnie was made captain at the time he'd a) still be playing, and b) aussies wouldnt lose many matches.
best cricketing brain (warne) for a couple of decades IMHO
theory on angle ;
whats the diff between a right handed bowler bowling to a left handed batsman ? there are plenty of left handed batters too.
He does stray a little sometimes. But his figures speak for themselves.
Most wickets and best avg this calendar year. How can you say hes crap ?
Id be more 'scared' facing reid (back in the day) than johnson.
Johnson leaks runs, plus you know you'll get a straight short one (guaranteed) for a hook/pull and a wide one begging to be cut for 4
if we are talking variation than Tait would be the best bowler out (yeh fat chance) simply 'cause he cant string two good balls together
fact is, left handed batsmen face a hell of a lot more deliveries from right handed bowlers, over rh batsmen facing lh bowlers - there arnt all that many left-handed bowers out there.
practice makes perfect.....
RB20's are tough little luggers, mine has between 80 and 92PSI on ALL 6, and it has oil in the water, but it still pulled quite a decent figure a couple of weeks ago..
and it blows smoke too..
LOL my old 20 was the same aye. Blown head gasket, blown water pump and a big arse crack in the exh mani right at the collector and it was still cranking skids right till the end :D
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
