  • Replies 14.2k
yeh i cant say im liking internode atm..
say i can get adsl2+, im 2.7kms from the exchange, i ONLY have my modem connected (no phones) and the modem is a adsl2+ $300 belkin router/modem..
and i get this shit connection.. cmon my vodafone 3g card was better and that was shit!
first day with internode=fail..
I'm gonna go ahead and say it's not a problem with Node and more likely something on your end. Tried calling tech support? They should be able to sort your issues. Oh and when you get the chance, piss off that Belkin, they make nothing but shit. Buy Billion, cheap, functional and awesome
almost ready for sanding. yay
thats really impressive mate! your bloody hard at it arent ya! cheers for ya help ova the fone! got both shafts out and upper bellhousing bolts now just gotta get the top startermotor bolt, fuel lines and oil lines to filter. then ITS ALL COMING OUT BABY. hopefully have it doen by mid arvo... got 5 days off starting tomorrow
Check my build thread for more updates in the projects section :)
off to the paint shop in a couple of weeks, new battery tray bit getting welded in to get rid of the rust. And painted engine bay.
Andrew (blue32) popping down this weekend to help with the engine assemble. (still gotta msg) :D
All happening :laugh:
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
