  • Replies 14.2k
loosen the gearbox mounts and take the engine mounts off the engine as its most likely pulling up on the box and wont seperate from the input shaft
had the same problem with my 3 motors
thanks mate ill get onto it first thing in the morn.....
Dale, do you have anymore 215/45R17s in your treasure chest??
No sorry mate i forgot to reply to your SMS the other night. I'm not sure what i ahve got but i'm 99% sure that there aren't any 215's in there. I do have a full set of 205/50/17 but i'm not sure that i want to let them go as they are hard to find and have the "same" sidewall as 235/45/17.
i stick with what i know.....more research needs to be done in looking at caltex's 98RON fuel by me...so for the time being sticking with BP Ultimate 98
i've been using the caltex 98 for the last 6 weeks, has been working perfectly well. its the exact same fuel mobil sell as 98 octane
-D
i paid 135.9ish before it get cheap for Tuesday. I dont really take much notice of how much fuel costs, even if BP ends up being 125 compared to 135, the saving in your pocket isnt enough to cover the pack of chewies you bought while you were inside.
other thing is, u can get 4c off per liter using the shopadockets thru caltex-woolworths and shell-coles...
-D
sale of wheels saga, entry number 46734:
found another dude whos keen, some random apprentice that owns a hr31 coupe, shall be collecting a deposit soon. rad.
any suggestions for new wheels?
No on 11rs. Yes on CST.
But why are you bothering on wheels if you want to sell the car?
I've always sworn by BP 98. With all my turbo cars.
I'll even go out of my way to drive to a BP to fill up.
It's how I f**king roll around here. BP = Big Penis. That's why I go there.
Im confused. Are you going there to use (stroke and/or suck) the "Big Penis"?
Cheers for the bday wishes guys.
Feel free to buy me...
nismo engine and trans mounts
just jap catch can with washer bottle
tomei sump baffle
mines cam baffles
nismo front bushes
gtr steering rack
cheers :huh:
Happy birthday Luke!!
wooop, we may have just found our new home!!
4 bedroom with TWO garages and a carport, for a price well within our range!
only thing holding us back is selling the unit, and missus being on maternity leave...
fingers crossed
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
