  • Replies 14.2k
lol, ebay rocks
panasonic blu ray home theatre system, (inc sub and 5 speakers etc etc)
grand total of $142.50.
i half expected it not to work for that price, but it looks and plays like brand new!
win
When u got the right tools, some know how and some mates who know how to help out it really does help.
Got Andrew coming down Monday to start with the engine. Hopefully I got everything now.
Next is some nismo parts to freashen up the front end. So hopefully in 2-3weeks it will be all running.
loving it mate! yoiur updates are still my source of inspiration!
fitted these saturday.. such a pain in the ass, alot of cutting and stuffing around and they still arent perfect but abit of black silicone should help
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
