Yeah just making sure man, I think mines playing up :\
Anyone got any idea on what the cost would be to get new innards of it?
I have a spare one you could borrow/buy Wayne. :P
  • Replies 14.2k
That would be fantastic Rubz :).
Only thing is right now, Its really hit and miss problem, and does it at the weirdest of times, I really wish it'd just sh!t its dacks so I can replace it and be done with it :P
Ummm, I'll get back to you Rubz, whats it worth?
Cheers man, I'll see what they are brand new but Rubz PM me what your chasing?
This is ofcourse, if the cas is on its way out - Pretty sure you can't test them either if the problem is intermittent (sp) which is a pain.
what exactly is not clearing???????????
i thought Dale said it would clear with no problems...................... :P
AFAIK, they were bolt in items on the RB25's, but they were also designed for RB25's in R33's not R32's. I suspect that adrian will be using the RB20 mounts (the metal engine side bracket) on his RB25 because they run the angled engine mount unlike the R33 that have the flat horizontal mounts. If he swapped the cross member over to a R33 one then that theory goes out the window.
Speaking of RB20 mounts, have you still got those mounts Craig?
so if i high mount it will i need a custom cross over pipe? will it fit with the stock one in place?
Just get one of those greddy copy intakes, you can pick them up for around $300 now and they aren;t as bad as they were when they first came out. The one i ahve is as good as an actual greddy manifold (well the pictures i have seen of them anyway)
Sounds just like an AFM proble
I had similar symptoms till I replaced my AFM's with some reconnect ones. Pete at PLMS can recondition the AFM's if it turns out to be them..
-D
I just left a thing on your FB but I'll post here,
Ummm, every now and then my car will drop idle and bounce round for a few seconds and then idle and drive fine, then other times i'll be cruising at whatever speed/RPM and it'll do the same similar thing just drop like all power etc for a few seconds and then act and drive fine.
In my old VLCT, I experianced the same thing with my RB30ET... Could be AFM's too :\
How much boost is your rig running?
hey champ iam running 15psi flat no tapering on this tune stock is around 6psi on xr6t's mine is prolly one of the lowest powered modified units around the s.a streets i gotta keep it useable due to it being a family wagon :P wench has to drive it daily :rofl:
mind u i did put my name down to go to the boostworx dyno day but as u guys would know it got postponed(any one know when this will now be?) mines no dyno queen tho cause i got the hi stall and that soaks up a few rwkw but high numbers dont mean much to me iam after the lowest number 1/4 mile is where i like to play.
any of u blokes head to the strip regually?
btw that lala time is very respectable champ well done is urs 4wd?
Edited by JETURBO
nice work dude get it out for street cruises offen?
on this note u blokes interested in a small gathering one time if theres enough intrest ill get the lads together and make a time and place and see what these skylines really go like.
u blokes into the hills runs or carpark to carpark jobby?
whats the general number at a typical gathering?
for us its around 10-15 but as u know to many is just havoc
im gonna have another crack at fitting this ass of a thing. i really wanna stay low mount..
worst comes to worst ill get 6boost to make a manifold that fits it!
but thats once i have tried everything..
Had it out Friday night for a hills cruise actually. I'd be keen for a meet up in the hills, we don't really do any big meet ups anymore because of the heat from the cops, but more than happy to hit the hills in a smallish group.
the low mount 6boost mount manifold will NOT allow u to use your crossover pipe as the runners will be too high (higher than the rocker covers) being a tuned length design, and u will defiantly have to machine the engine mounts a little to clear the compressor housing and have a custom intake and dump pipe made up
as Dale said u will need either a Greddy style plenum or any front facing plenum or a modified standard one, which will be better as u will use less intercooler piping
Edited by ovrtym33
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
