In my opinion, I would rather do something I am 100% happy with and enjoy, even if it did pay 2/3, over something that stresses me or makes me unhappy 3/3 salary.
100% happy and being paid 3/3. I'm not moving any time soon.
+1
My job has varied so much in the 10 years, its never gotten boring. Sure I lock horns with the business owners from time to time, but we're professionals and we all know its in the best interests of the business. Just like this new bill system upgrade we got ... I was against it claiming there would be problems, sure enough the system has caused many dramas already. But I don't complain, I find a solution and the bosses are happy. Bring on my performance review! :ermm:
I have regular "business status" meetings with the bosses weekly (such as this morning) which I find boring tho. :)
  • Replies 14.2k
Hmm, can't seem to find any place that sells holesaw kits for my intercooler piping. Been to Bunnings, Autobarn, Repco, Supercheap, and many others. Who the hell sells such a thing that I consider a simple tool? Might just do it the traditional way and mark out the circle using a suitable cup size and drill out the circumference!
Fitting new piping kit this weekend :ermm:
hey mate, try Heatley Tools South Rd Wingfield.
use a compass, then drill it out with a suitable bit for a air saw blade to fit thru, two second job, then line it with a proper trim molding to prevent rub thru
air saw will go thru it like a hot knife in butter
On another note, who here actually enjoys thier job? Am I considered weird for actually enjoying what I do?
lol. i f**king hate my job. work shit hours, earn shit pay, cop it from some of the worst civilised society has to offer, and generally spend most of my time being stressed out. its awesome.
meh, new start in a couple years time if/when i come back, ill worry about doing something i enjoy then.
Try Total Tools, Cormack rd at Wiingfield
http://www.totaltools.com.au/icat/index.php?id=H
Fitting new piping kit this weekend :(
Wish I was too :)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
