I was running twin 12" thermos on a dedicated track car and a disconected clutch fan.
i found that temps went abit weird and all over the place (had the thermos wired and re-wired a few different times to fix the problem and nothing)
hook the clutch fan back up and she was sweet. this was on an sr and ive had another mate have the same problem with his rb20 and his new car (black top sr)
like i said, it was my personal opinion and on a track car i didnt like it and neither did my car
  • Replies 14.2k
Abe, help us to help you buddy.....ie.
How much power are you anticipating?
How much track work will the car see?
Is it your daly and if so, how much rush hour driving will it see?
and most importantly, what is your driving style like, ie. boot into it from most traffic lights (which is how I drove when I was younger) or just the occasional squirt, etc?
All the above factors have a big say on clutch choice but having said that (and as Steve stated) you couldn't go wrong with that NPC setup from the little I know about you and your car.
Hope this is all helping bud, cause I was the same when I was trying to decide on turbos and zorsts before selling mine.
Thanks for the help Pete.
At the moment it has ~260rwkw, will eventually go higher when i rebuild the engine - if it dies.
It will be seeing 1-3 Days a year at the Track - Depends how many SAUSA does.
Yes, it is my daily, generally it is a straight run to work, with 1-3 traffic lights. But as for slow moving, bumper to bumper traffic, very rarely - hardly go anywhere near town, closest i get is maybe Vilis :D.
Take off from the lights is generally sedate, but will sometimes give it a bit up to the speed limit, also very rarely go for hills runs, but will be going on a few more hopefully as i now have weekends off :(.
what fmic kit did you get? you shouldnt be cutting up your fan (found out the hard way)
also, personal opinion, thermo's are shit if your also removing the clutch fan.
Never said I was cutting up the fan ... hence why I removed it.
I've removed the clutch fan and fitted thermos to my previous project cars ... including a supercharged SR20DE powered 200B and CA18DET VG30BB turbo powered 1600, and never suffered overheating.
I'm just asking what thermos (for those who are) are being used on RB25DETs.
I'm running a single 14" thermo and even on the track i have no problems with temps.
The problem with clutch fan is that they produce parasitic loss all the time even if the temps are fine. The advantage of the thermos is that they only produce a power loss when the cooling is actually needed which you will surprised to know is only around 30% of the time (more if you are in stationary traffic obviously). When the car is moving generally you don't need any more air flow than what you are getting by the car moving through the air.
Which is my thinking too. What 14" brand are you running?
I'm also running a 52mm alloy radiator. :D
We found in our old drag car that the a/c thermo off a vr/vs holden did a fantastic job, but they are a 16" fan. Other than that try to get one with curved blades and preferably with an outter ring to stop the blades flexing too much.
LOL, sounds like James would make a good candidate for a Mod with his stick wielding talents .......**mental note** :D
yep thats a definate, theres a couple of people from that party im willing to bet are still showing the marks of a good banning now.
never said you were cutting them (i can read and saw what you said) just said you shouldnt also why i asked what fmic piping kit you had as despite the kit you shouldnt have to cut the fan blades as any decent kit made should fit between cam cover and fan shroud without hitting the fan, thus no need for thermo's on a daily car. :D
get thermo if you want was just trying to save you the time and money as they arent needed. also gave you the brand that ive used so go for gold :(
Edited by Import S13
i like to think of myself as a pretty patient guy....
BUT FOR PHUCKSAKES I WANT MY SKYLINE BACK AND FINISHED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
that is all.
Err....fairly sure that needs to be changed. :)
Does it?! Why does it need to be changed? Last time i went for a hills run was...ummmm, the NS Christmas Cruise, where i got lost...again.
that is all.
Yeah, i know what you mean. Mine has been off the road for 2-3 weeks with a fried clutch, and its going to be about another 2-3 weeks before its good again :)
Yes, it is my daily, generally it is a straight run to work, with 1-3 traffic lights. But as for slow moving, bumper to bumper traffic, very rarely - hardly go anywhere near town, closest i get is maybe Vilis :).
Take off from the lights is generally sedate, but will sometimes give it a bit up to the speed limit, also very rarely go for hills runs, but will be going on a few more hopefully as i now have weekends off :).
Aberax i see your having troubles deciding what clutch to choose..... I highly recommend the same one that i got which was through the group buy that madaz did. I had an R33 GTST with 250 RWKW and i hammered the thing with no problems at all. Before this i went through 2 other clutches. The NPC setup was VERY easy to drive and was capable of a fair amount of abuse ;). Good luck in what ever clutch you choose to go with :)
that is all.
Ive been waiting since November for my engine. Been driving an R32 with a busted engine since October. I win :)
Aberax i see your having troubles deciding what clutch to choose..... I highly recommend the same one that i got which was through the group buy that madaz did. I had an R33 GTST with 250 RWKW and i hammered the thing with no problems at all. Before this i went through 2 other clutches. The NPC setup was VERY easy to drive and was capable of a fair amount of abuse :) . Good luck in what ever clutch you choose to go with :)
Sp you have a 5puk Ceramic from Steve's (Madaz) Group Buy? Did you also get the Flywheel too, or have your old one machined?
^^^There you go Abe........just get the NPC bud as it's less than 1/3 of the cost of a Nismo and very good clutch for the $$ by the sounds of it
that is all.
LOL i don't know what your complaining about, my cars been off the road since march last year and i have only now just started to build the engine.
It's just a generic one off eBay.
Edited by D_Stirls
hi abe im oz pommys dad
we just had his standed flywheel machined the npc clutch worked a treat and had been in the car over 12 months before he sold the car .
it copped a fair hammering in the time he drove ....i mean thrashed it lol . b4 then i had fitted 2 clutches in about 18 months too the car
pedal had good feel and the cluch was good in traffic
cheers dean
that is all.
im in the same boat as you boys but i havnt driven my line in like 6 months :)
i have had my 31 since october, and only done one skid. depressing.
workshop has had it for >5 weeks. depressing.
i know there was a fair bit of work, but geez, srs?
Whats being done to it? I had just assumed it was ready to slide lol
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
