  • Replies 14.2k
think i need to clean the rubber off the Ceffy and you can see where i gave the tyre's a tap coming onto the start/finish straight, fair lucky not to lose the rear bar.
Edited by DSTROY
Gtr as a daily 34 as a project.
theres several interesting 32 gtrs on carsales atm
one is #78 of the original aussie delivered 100
one is a tommy kaira spec 32
and another has only 9800km on the clock...
whats ur budget? :D
-D
whats ur budget? :D
-D
I so wouldnt mind that TK R32 GTR... but its so ugly and not in my favourable colour.
Excessive lowering will give you too much toe in, unless you have adjutable upper arms
stock suspension now and stock arms
only adjustables that were in it were coilovers and rear camber arms
will have to put hicas back in
could that be the problem?
Proves that you are driving it properly!
it can affect hicas if the toe is greater than 2' on either side, the hicas computer senses it somehow and disables hicas after about 15 minutes
for what its worth, i got some rear adjustable upper control arms last year for around $350 and the precise adjustment that the aligner was able to make more than justifies the cost... makes the car perform much better with less tyre wear to boot ;D
not regency friendly, but theyre easy enough to get engineered
-D
-D
i think you'll find what ive had to remove :D
Is that all?
*sigh* its enough to throw his geometry all out of wack again
he has the front castor arms, the rear camber arms, the adjustable suspension... all 3 things that work in tandem to ensure the suspension actually works properly
u should enquire about getting that stuff engineered man, rory thompson does it for $500 odd if I recall correctly, and that mean you could continue using the control arms for caster/camber... not the suspension but eh, 2/3 is better than nowt
-D
Yeah my suspension was out of whack when I removed everything for regency, handled like a bucket of shit on the way to Tyre Power for an alignment which straightened everything out and made it feel perfect again afterwards.
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
