*sigh* its enough to throw his geometry all out of wack again
he has the front castor arms, the rear camber arms, the adjustable suspension... all 3 things that work in tandem to ensure the suspension actually works properly
u should enquire about getting that stuff engineered man, rory thompson does it for $500 odd if I recall correctly, and that mean you could continue using the control arms for caster/camber... not the suspension but eh, 2/3 is better than nowt
-D
my mate has a 31, with coilovers, and was successfully engineered, and passed regency.
  • Replies 14.2k
just has to be legal height when engineered and their fine
what he said... my coilovers (both sets) are non adjustable and are regency friendly
its the adjustable caster and camber arms which are the biggie
height adjustable is not permitted at all
-D
apparently those pedders coilovers can be engineered at whatever height you want.
just what ive heard from troy at tyrepower, hes done the leg work to get a couple cars engineered.
Edited by scandyflick
probably would be the go. having run bilsteins and teins, they both have their benefits, but the ideal setup would be something in between
the teins are stiff, which is good when the road drops out from under you, but is a bad thing when the road slightly undulates as you find the rear end bouncing
on the plus side, its a progressive rate spring so it absorbs the initial impacts better
the bilstein is lower and has a softer spring rate, which is awesome for cornering and general use, however then the road disappears from you (aka a dip) your arse just dumps to the ground and u end up scraping the exhaust on the tarmac
i'd love to know more about suspension, its an art and a science of which i know nothing about
-D
Same here Dohmar, hopefully Tafe deliver.
As you probably do, google is your best mate on this one.
Only just learning how toe in and toe out affect the car via some site.
yeah the suspension is the hard part, spring rates, rebound, bump, sag, valve pressure etc - thats the hard part
caster is easy.... the more positive front caster, the better
camber is easy... couple degrees negative camber, alles gut fur street und track
neutral toe for the gtr rear with hicas, and 1' inward toe for the front
thats what im running so far, altho i need some new front caster arms to correct the pull to the left hand side
-D
Height adjustable coils can be engineered. Mate got his greddy ones done, aswell as his Cf bonnet >_<
who'd he get em engineered thru?
Would be nice to get ISC's coilovers engineered as a group thing, so everyone who runs them has some kind of cert to help with regency
-D
toe is something you have to be pretty careful with.
it can either make your car handle beautifully, or turn it into an absolute dog.
totally... which is why some people love the 1' toe in that HICAS delivers, and some people hate it
really all depends on the response of the HICAS itself and the driver, but I guess im in the minority when I say I really like my HICAS and am happy to have spent the effort getting it working right, rather than just locking it
0.02c, your mileage may vary
-D
hicas, tits on a bull = same same.
depends on your mindset.... japs designed it for a reason, and that was to handle touge runs better than the competition....we dont quite have the same twisties (or road quality) that the japs do (sadly)... its less effective in aus I'm sure considering the amount of time our wheels spend off the road due to the crap quality of our asphalt
general racer concensus seems to be that hicas is a hinderance on a proper racetrack, which I can understand the argument behind this, however I'd also point out that nissan thought it convenient enough to keep on all their R series cars from the r31 up to the 34 so it can't be >that< bad
Disclaimer - I'm no performance driver. I just do hills runs for my jollies.
-D
Quickly everyone, I need help with tyre size choices!
I have a set of Work Meisters as some of you may know, sizes of them are 18x10 +13.
Being on a 32, these offsets are fairly agressive as most of you too would know...
Do I go for a 245/35 or 245/40
I want to try and dodge rolling my front guards, but will be getting my rears done. Opinions PLEASE.
u need to work out ur rolling diameter from stock vs what u want to put on
otherwise your speedo will be out of wack and that will affect your attessa and hicas
best bet is to check a tyre placard and see what nissan actuall recommend. wish i could tell u what size u want, but i cant be stuffed...
-D
I don't think Nissan will recommend a 18x10 fullstop lol
I think they would not recommend it, due to homologation rules; below is taken from skyline wiki:
Under Group A regulations, a turbocharged engine must multiply its engine displacement by 1.7, putting the new Skyline in the 4000 cc class, and requiring the use of 10-inch-wide tires. Knowing that they would be required to use 10-inch-wide tires, Nissan made the decision to make the car all wheel drive. Nissan developed a special motorsport-oriented AWD system for this purpose called the ATTESA E-TS. Although this assisted with traction, it made the car 100 kg (220 lb) heavier; the added weight put the GT-R at a disadvantage to other cars in the 4000 cc class. Nissan then made the decision to increase the displacement to 2600 cc, and put the car in the 4500 cc class, with the car's weight near-equal to competing cars. The 4500 cc class also allowed for 11-inch-wide tires.
I think you're safe dawg.
-D
Is there a difference to them saying tyres and wheels? As I'll be stretching a tyre on my 10" wide wheel to make it easier for them to fit my guards better and not be mexican spec aha
ask scandy. hes the king of tyre philosophy imho
-D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
