  • Replies 14.2k
Although those 35 gtr brakes look all nice and everything u gotta think about all the extras. U may only get one or 2 track days out of them before u crack a disc, so there goes a grand or more, then pads, then lines made up, mounts made up. Probably be close to 7k before u have them working how u want them to be.
epic lolz today at the mini driver crashing on the warm up lap of a practice session doing the zig zagin :P and not just a light hit were talking major front end smaking. ripped off front bar looked maybe a bit of steering damage to
ummm , not sure what suburb it is but the one on north east road near the ABC building :P
That's Collinswood.
You wouldn't have been on last night would have you? called in for a snack wrap for the GF and a Big Mac for me but when i got home there was no meat in the burger, both patties were missing.
I can hear them too. Makes me sad!
Oh well, I guess i cant complain...im heading to Gold Coast on Sunday for a holiday.
So, right, I knew my tires were getting pretty bad but last night I could hear this noise like I had a stone or something stuck in it. I get out and have a look and a huge strip on the inside going all the way around was coming off! I havent had a tire do this before. I pulled it off and now on the inside there is a 1cm wide by 2cm deep strip mising from my tire and I can faintly see metal in the hole. SHIT! I was going thorugh the hills the day before too and its my front tire. I deserved a defect.
That said, Pitlane said they can do me a deal on tires. Im pretty sure they use Federal but not sure. Anyone here use Federals? Im not planning on spending heaps and I think he said about $220 each so thats pretty good. 18".
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
