  • Replies 14.2k
yeh love, Ive had arthritis developing since I was 11.
32 now, knees removed without replacement, 2m tall - takes its toll.
currently on mobility impaired pension. seeing i cant do diddly squat
yeah it hurts dosent it
i had to do x2 refills yesterday at work and iwas almost crying with the pain
i have also decided to leave the salon now cause it dont want to build it up and then have to leave anyway
yup, sure does.
shocking loads of pain - definately been there before.
I feel for you
what stories might they be?
A good mate had them on his 180, he found 7 had stripped and 3 had come loose. few other stories of tyre places stripping them. Also can seize, due to the different expansion rates between the steel wheel stud and alloy nut.
yup yup alloy is to soft
james im getting jager for tonight want some?
lol thanks craig i want this one
http://www.trademe.co.nz/Trade-Me-Motors/C...n-281129066.htm
I'll be right Kel, got a bottle of Beam sitting here waiting :P
I was thinking of bringing some along tonight too - if you mean Dion's.
I think i may just bring along a 6pack of CC and maybe something good for after...not too sure atm, need to save money for new tyres and tie rod ends for next week.
so, ive got this set of rims for a mate's lad's 31. dad wanted to see what they looked like on his barina (just in case the guy doesnt like them)
i lol'd a tiny bit
gone from a 13x5 at about a +40 to a 16x7 +20(ish)
suffice to say, i DONT think they'll fit somehow
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
