  • Replies 14.2k
5stud, 2-pot single-sided fronts, 1-pot rear's
fixed a leak at the caliper (thru the bloody thing, nuts that keep the caliper together wernt tight enough)
the dust guard seems to be making some noise, something....... unless it's the pads against the rotors
yeah, should be able to boof, i got a set of R31 rears on order from DBA as "blanks" as i need them drilled for 5 stud. costs a small amount more as they have to pull them off the run n that, but ya should be able to
Anyone able to help me out? Need someone to go to JIS, buy me some R33 Tie Rod Ends - $175, and meet me somewhere, ie vilis, and i shall pay you back. I need the suckers in my hand by Saturday morning. If you are able to help out, send my mobile an sms on 0411876139 with your name and number and i shall call you back.
Edit: If they aren't in my hands by Saturday Morning, i will most likely be unable to attend the track day...there is also $50 in it for who ever does collect them for me.
Thank you to Madaz and Ruby for sending me a sms about picking these up. I managed to speak to JIS today, and he said he was going to be there till about 6-7pm, so i managed to pick them up :( . Also had a little chat, looks like a few of our forum members are regulars there *looks at Andrew and Dave* :thumbsup:
Hrmmm seems i could be stuck with going non turbo 33 rotors...Can you buy rotors that haven't been drilled at all?
could just get Growley custom machining to redrill 5 stud to suit 4 stud i had him do that for me before i had a 5 stud conversion and no troubles
http://www.growly.com.au/
npz Abe good to hear your sorted
Yeah Dave and I practically live there. If I could have gotten to Vili's tomorrow night to give them to you I would have picked them up for you. I live less than 2km from JIS, so pop in to see Koji and Paul frequently :P
So many toys, so little money - there are always things there I want.
i have some rotors with matt atm getting redrilled from hq patteren to ford pattern for the race car he can cross drill or put a few different grooves for a pretty good price .
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
