  • Replies 14.2k
hey tuner, can i get a nistune installed and tuned? yeh sure thats $550..
car is now at boostworx getting touch up tune.. oh who ever did your tune didnt put a nistune in it.. so thats another $600..
wtf... i asked for a nistune so they just burnt a chip and installed it.. WTF...
anyway i can hit the first tuner for some compensation due to not doing what i asked and still slugging me $550?
Absolutely! Where did you go for this? PM me all the details pls
I went direct to pete at PLMS, he installed it and sold me a licence as well as did a quick tune, all for $500 - still needs a proper dynotune but that'll come later.
If all they did was burn a chip, I'd be majorly pissed.... esp for that amount of money
-D
ok so i have called the tuner AGAIA, and now he says that he didnt think i wanted to get the car tuned anywhere else but with him hence why he didnt put the nistune in..
is there more than one nistune? coz i asked for a nistune..
i didnt think there was more than one nistune..
any ideas what i can do..?
he is pretty much not doin ne thing to help except tell me i should have gone back to him..
the idea is that on occasions like this when i need a tune ASAP and the closest place is boost works then i go there...
If you asked black and white for a nistune board, then he has to provide man,
as far as forcing him to pay out etc I don't know, its harsh but sometimes easier to deal with the loss, spread the bad word amoungst everyone and move on.
Hope you get some coin out of this bastard though Age!
oh im furious..
he says now that he didnt understand i wanted a nistune to be installed..
like how may nistunes are there? i caled a few workshops and asked
"if i want a nistune and remap what would i get?"
they said "u would get a board installed into your ecu and a image put on to that(remap)"
dont think its too hard eh?
I completely agree with you man,
Just ring the tuner up and be completely up front with him, say you want a refund to recouperate 'some' of the funds and see what he says. Be firm about it don't let him talk you out of it. Scare him with the power of 'Word of mouth' :P
Being the import scene, few bad stories going round of this particular 'tuner' and he will loose alot of his income that'll hurt him more.
I doubt hed give a refund, but as a gesture of good will it would be acceptable for the tuner to finally fit a nistune board (if it hasnt already been done at bw)
Otherwise then I suppose a refund of $240 for a board that was never installed would be appropriate
-D
As i said to Adrian on MSN i don't think he quoted for the board, a board + install + tune would be around the $7-800 mark. So what he paid for he got but there was a communication breakdown some where. If he paid $7-800 then he should get some money back.
-D
Thats what I meant,
The idea of Adrian getting a full refund is not likely.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
