any of those kiwi's but the one on the left, ex lap dancer, bit fake and used up looking up close
prefer the blue in the middle, shame they speak funny, farsh and charps
tangles your not far from morphine ville,, the down south dump.druggies on every street corner. so sick of the crime in this town. lol
  • Replies 14.2k
lol. i think a 30det is a little out of reach for your average backyarder.
ok let me try again...
who can build a 30det cheap ? (if i provide head + block + pther little bits). Any idea how much a workshop wud charge to just put it together ?
lol
hi locky im kellie
ok boys i need some really good pointers for a job interview for tomorrow, it is going to be a behavioral interview
the job is for a insurance under writter
Try not to use the "F" word Kellie. I know its hard, but concentrate okay! :)
:D
Try to anticipate the type of questions they are likely to ask. Keep answers short and easy ... and relax. Good luck with the interview.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
